Things to look for in a e34 540?
  • 416stroker
    • May 2008
    • 2448
    Im looking for a e34 540 car is there anything to look out for specifically?
    I know about the cylinder wall problem thats all.
    84 318I Delphin RIP
    87 325IS delphin 24v Sold
    89 325 Alpineweiss
  • naplesE30
    • Nov 2007
    • 1841
    maint records, thrust arm bushings, make sure if its an auto reverse engages quickly and properly(usually the first sign of tranny problems) if its a touring take a good look at the wiring at the rear hatch as it can be a nightnamre to fix once it starts to fray. Do a cluster check to make sure mileage is correct. Push in the button on the right side of cluster, while holding in button turn ignition to on position. Cluster will go through aa series of checks and display the vin of the car the cluster came with. Thats all i can think of off the top of my head.
    • 416stroker
      • May 2008
      • 2448
      O I will do all that all the cars im looking at are autos so thats good to know
      Mainly im leaning to a 540it auto car. I look at my other option. Today a 540I auto sadly.
      But its old folks owned so it could be a good car its a 1 owner
      84 318I Delphin RIP
      89 325 Alpineweiss
      • Kovs
        • Oct 2006
        • 483
        They never made a 540iT for the states. If you want a V8 in an E34 touring, it has to be the 530iT.... I would try and find one with a blown motor / trans and swap it out for a M30B35 with a 5 speed.
        Mike
        82 Alfa Spider (For Sale)
        86 944 Turbo
        87 CX25 TRD Turbo2
        89 405 Mi16
        89 Milano Verde
        89 Mondial t Coupe
        92 300D
        • 416stroker
          • May 2008
          • 2448
          Yes I ment a 530it
          84 318I Delphin RIP
          89 325 Alpineweiss
          • Jean
            • 18228
            530i are not even worth it unless it's a clean body/interior.... m60b30 is a turd.
            540i auto kills it, look for manual man!
            v8s = leaking valley covers, (requires removal of harness/fuel rail/intake manifold) to do water pump/o-rings/gaskets etc. Leaking power steering/boxes.
            All e34s suffer from shitty front suspension/steering components
            Shitty door panels and some with shitty headliners
            LOTS AND LOTS of electrical components in the AC/Heater system
            But they make awesome DD cars.
            • mikeedler
              • 6707
              didn't read the rest, but worn supension, and brittle plastic and rubber.
              • TimR
                • Mar 2008
                • 549
                Make absolutly sure the intake manifold & pullies looks original, untouched, if it had a supercharger and it was removed to sell these would show signs of removal ETC
                • StereoInstaller1
                  GAS
                  • 22679
                  Fixed your post
                  Closing SOON!
                  Thanks for 10 years of fun!
                  • StereoInstaller1
                    GAS
                    • 22679
                    'nother fix
                    Closing SOON!
                    • CleanAzzE30z
                      • Jan 2004
                      • 11794
                      Did the 3L V8s not have the Nikasil problem? My brain is so full of random BMW facts that some are pushed out like a constipated turd.
                      • Jean
                        • 18228
                        Luke - lol
                        Or that could actually be a good sign that someone bothered to replace the old gaskets.....
                        Yep.
                        • Van Westervelt
                          • 9365
                          They did as well. All m60s suffered this sadly.
                          • Jean
                            • 18228
                            But m62s did not, easy upgrade ;)
                            • 416stroker
                              • May 2008
                              • 2448
                              Ok I passed on the 540 the car had a weird stumble.
                              It fellt like a jerky trans.
                              Tomarrow I sealed the deal on a 525it
                              84 318I Delphin RIP
                              89 325 Alpineweiss
