So i recently changed my thermostat on my car because of overheating and it fixed the problem for about a good two weeks. Now it is starting to overheat again but i did not do a proper bleedin of air and only filled it with water because this car is parked in my backyard and is a project, its barely being driven. You think that would be the problem because it was good for 2 weeks. It overheats within 10-15 minutes at idle... It also shakes a little. (idk if that has to do with anything relating to the problem).
Quick Question About Overheating
Get a old news paper roll it up while the car is hot and running put the newspaper in the fan (not all the way) if the fan stops real easy then its fucked.
It could also be your water pump is the car leaking any water. My water pump shit its self same problem would over heat during idle but was find while driving.sigpicComment
