Turbo M20 guys, what gear ratio's are you running?
  • z31maniac
    • 17566
    I was thinking a 3.25/2.93?
    I'm wondering if the 2.93 might be a bit too low.
    Thoughts?
    www.gutenparts.com
  • Andy348
    • Sep 2009
    • 688
    Quick search on e30tech:
      • 34844
      depending on what you want to do - I'd try the 3.73 first.
      • JTapper
        • Sep 2009
        • 847
        I have a 3.73. It's too short.
        Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
        • z31maniac
          • 17566
          Autotragic 'vert, so 4.10.
          And I know that will be too short. I'm leaning toward the 3.25.
          www.gutenparts.com
          • der affe
            Technical
            • Dec 2005
            • 8452
            a 2.93 will be easier to come by as it is orginally from an e 30.
            IIRC the 3.25 is from an e28 with a different cover and flanges.
            i know of a few 2.93 lsd rear ends at a local pnp. one is from a low milage auto eta. if you are genuinely interested.
              • 34844
              people have this wierd idea that they'd rather be "boosting". I'd rather be accelerating, boost is just a pressure delta. :)
              4.10 is definitely too short though, lol. not unless you want to build an 8500rpm screamer :D
              • ejnight
                • Apr 2007
                • 3488
                3.73 but mine is a 10psi car with 29lb injectors. Does just fine.
                http://raceskids.com/
                • z31maniac
                  • 17566
                  I'm just thinking even a 3.73 might end up being a hair short based on the power goals.
                  After reading up on dynamic compression vs RPM when it comes to the load the engine sees. I'd rather push more boost at a lower RPM, then run less boost at a higher RPM.
                  www.gutenparts.com
                  • bimma360
                    • 1940
                    DO NOT do a 2.93... I have freakin grown to utterly hate mine. Having said that, I'm tossing a 3.73 back in. I am guessing a 3.4x Would be ideal, but I really wouldnt know. I'm with Nando, I rather be accelerating.
                    E30 Dinan Turbo
                    • z31maniac
                      • 17566
                      I'm just thinking a 3.73 with 450-500hp/tq at the crank, that even a 3.73 is going to make for short gearing.
                      www.gutenparts.com
                        • 34844
                        Not if you can turn it past 7k :)
                        • 325ix
                          • Aug 2009
                          • 7783
                          And that would definitely be fun! What does an m20 need to turn that high? I'm guessing rockers, valve springs and a cam on top and at least arp studs on bottom. Or is it good to go that high stock in good condition?
                          • reelizmpro
                            • 9558
                            3.25 feels perfect to me.
                            88 M3 - LACHSSILBER
                            89 M3 - ALPINEWEISS II
                              • 34844
                              New OE BMW parts and an appropriate cam will do 7200+ all day long.
                              Springs are more dependent on the cam choice, so obviously an agressive cam will need stiffer springs.
