Love the car obviously but I need something larger. Selling it so cheap since it needs a few things.
The vanos seal, it works as an EGR and my HC and NOx results were high but passed in September. I had a hot air intake when I had the car BAR'd, so that may be the reason NOx and HC were near the limit. May or may not pass smog, it's your responsibility. Second issue is the top has shrunk, so there is a slight gap at the trunk. Guy in Fremont area is selling a nice black one with clear windshield for around $400. Also leaks a little oil from the main seals and the dash has cracks. Windshield also has about a 5" crack.
Mileage is 190k, title is salvaged due to back registration fees from PO. Changed the oil and filter every 5k with Amtecol full synthetics. Only use Chevron, 76, Shell, and Mobil 91 octane. Drive about 100 miles to Livermore and back 3 days a week for work, so the car doesn't see much city driving. Family has a shop in Albany, so the car has always been well taken care of.
Engine/Drivetrain:
New cam sensor
New crank sensor
New O2 sensor
New coolant sensor
New NGK Iridum plugs
New water pump
New thermostat
New thermostat housing (metal)
New valve cover gasket
New oil pan gasket
New belts
New Sachs clutch kit
G240 with Amsoil Synchromesh
New e21 trans mounts
New m5 motor mounts
New reverse light switch
New fan switch and electric fan (not installed)
New radiator
Chip tune as well as factory
4.27 LSD (cabrios only) with Amsoil 75w-140
10w-60 with Full filter done 100 miles ago
KAmotors cold air intake
New fuel filter
24lb Bosch gen IV injectors
Dynomax turbo muffler
Chassis:
Ground Control coilover conversion
500f 800r, similar to what Mark runs in his vert
Ground Contro touring camber plates
Ground Control rear shock mounts
Front strut brace
Skid Guard's front subframe cross bar (NIB not installed)
KYB AGX's all around
Condor rear 12mm riser subframe bushing kit
Condor rear trailing arms
Condor differential mount
225/50/16 Bridgestone Potenza RE-11's
wearing evenly with plenty of tread left
16x8/9 et25 Wagen CS1 wheels
New center drive support
New pads/rotors all around
E32 double brake booster and master cylinder
Motul brake fluid
Squared Motorwerks Morimoto H1 Bi-Xenon projector retrofit (LOVE Bi-Xenon!)
4500k Moiromoto XB35 HID bulbs
Morimoto 3five HID ballasts
3000k 100w high beams
Interior is in good shape, rear seats have a little sun damage at the top
Audio:
Luke Fisher aka StereoInstaller1 (German Audio Specialties) installed everything himself in our shop when he did the drive from WA to Socal. Spent over $2,000 on audio and alarm.
All new speakers(4) and tweeters(4)
The AMAZING crossover that makes these speakers shine!
JL 1000/1 with custom made enclosure by Luke
Alpine 500w rms 4 channel
Keyless entry/alarm with 1 remote and 1 pager
LukeBox with two 8" woofers
JVC Arsenal KD-A845BT
colors match nicely and can be adjusted to your liking
Body:
Spent almost 3 months and $3,000 on body and paint.
Work was done at Continental in Emeryville, and they give a lifetime warranty for oxidation/fading etc. (not chips/dents)
IS front lip and splitter
Brilliantrot original color paint
Fenders rolled all around by Alex Rodini (great guy to deal with btw)
Front BMW oem mudflaps
Chose the m50tu since I was planning to go FI (engines are cheap and easily found) compared to the s52. But it would be very easy to throw in an s52 if you want more power. It's been over a year and the car has some paint chips now, have a bottle of touch up though. They've been doing construction through Livermore since I had the car painted so it's been tough on the front end. (I don't tailgate either)
The Condor and e21 bushings also let in some noise, I like the sound, mostly forget it's even there until someone mentions it, most think it sounds cool though. Definitely not a bad diff though, was quiet before the bushings.
The ride isn't too bad either, similar to an e36 m3 with Bilstein sports. Very fun to drive spiritedly.
I'll get some better pictures up soon. Value on these cars, especially cabrios, have been climbing the last few years and would make a good investment.
Not interested in any trades, parting out, etc. Cash is preferred but a check is fine so long it clears at the bank. PRICE IS FIRM STOP ASKING!! Email me with your contact information, if your email sounds like spam, I won't reply. Thanks for looking.
