1989 BMW 325i sedan - $7700 http://losangeles.craigslist.org/sfv...960099413.html
1989 BMW 325i 4 door sedan with 180,000 miles on the odometer.
The engine was rebuilt in 7500 miles (9months) ago. TOP and BOTTOM, so this is for all intent and purposes a brand new engine ready to do another 180000.
Invested close to $6K in parts alone over the years, work completed by shop owner, and ASE certified master technician.This car has seen more time on a lift than most cars will ever see in their lives.
Originally the vehicle was an automatic, and had tan comfort interior. I converted it to 5spd manual with a Getrag 260 transmission, new clutch, and resurfaced flywheel (transmission replaced in July with a re-built unit. All new seals, synchros, and bushings). Oil changes done every 3,000 miles or earlier with 20w-50 Castrol, recently replaced coolant, transmission fluid, and differential fluid.
Interior-
Two-tone interior - Black / Tan
M-tech steering wheel
Black Carpet
Replaced dash- currently has only a few small cracks
M-tech shift boot
Black sport front seats (relatively good condition for original material)
Weighted Billet shift knob
New window motors and switches (all 4)
Suspension/Drivetrain-
BrandNew rebuild power steering rack
BrandNew power steering hoses.
Vogtland Springs
Bilstein Shocks
Brand new outer tie rod ends
Brand new front control arms
Brand new ball joints
Brand new M3 offset control arm bushings
Brand new wheel bearings (all 4)
Ireland Engineering front drop hats (NEW)
New drive shaft center support
4.10 Limited Slip Differential - (making this effectively the best 325is model)
Racing Dynamics front Strut tower brace
12mm Hubcentric spacers (front and rear)
New clutch master/slave cylinders
Installed Rebuilt transmission (July)
New driveshaft guibo
New driveshaft center support bearing
Engine/Acc.-
Complete Engine Rebuild just over one year ago. Head/Bottom End (NEW parts)
Replaced Fuel Tank/Fuel Pump/Fuel Filter
New Radiator/Fan Clutch (radiator contacted fan while engine was running, but is not damaged)
New thermostat
Timing belt replaced at time of engine build
New coolant hoses
Heated throttle body plate delete
New intake boot
New hood prop strut
All new gaskets
MAF replaced
All vacuum lines replaced (no leaks)
Valve adjustment done every 10,000 miles
Extra Relays will be included with sale (I have never needed them)
17.5# rebuilt and flow tested Bosch injectors
Custom Exhaust split Y with quick change flange (not too loud, good tone) custom straight pipe will also be included.
Wheels and Tires-
Watanabe 15X7.5 RARE original true 3 piece wheels Custom Powdercoat
Falken Azenis RT-615K 205/50ZR15 (less than 6K miles)
Hub stud conversion (ringer racing)
Gold extended lug nuts with key
Stereo-
Clarion reciever
Hertz 6 1/2 inch speakers X4
E30 premium tweeters
Kicker comp 12" sub with custom enclosure
Hifonics amp
Exterior-
Lachsilber Metallic - Metallic Silver good condition 7/10
Euro Grilles
Black Kidney Grilles
Custom Sprayed Battleship Pearl Plasti-Dip (to protect paint)
Custom modified front Volvo lip
Custom modified Taurus SHO side skirts
Rear Euro filler plate
Black Painted window trim
Things to note:
- No AC
- Sunroof guide is broken, working on replacing it.
Current vehicle mileage is just under 180K odometer still works. The ODO mileage in no way reflects the age of this car. As stated above, the car has had quite the transformation throughout the years. It runs and drives like it is brand new.
Included with the sale will be stainless steel braided brake lines.
Without Rims: $7400
CLEAN TITLE! Never been in an accident!
No trades. Cash in hand only. No BS or tire kickers
Interior-
Black Carpet
M-tech shift boot
Vogtland Springs
Bilstein Shocks
Engine/Acc.-
New thermostat
New coolant hoses
New intake boot
New hood prop strut
All new gaskets
MAF replaced
Wheels and Tires-
Stereo-
Clarion reciever
Hifonics amp
Exterior-
Euro Grilles
Things to note:
- No AC
Without Rims: $7400
