The Official 'Craigslist find' thread - awesome & awful (eBay, Kijiji, etc.)
This is a sticky topic.
  • Luke Girard
    • Dec 2013
    • 738
    #1816
    1989 BMW 325i sedan - $7700 http://losangeles.craigslist.org/sfv...960099413.html
    1989 BMW 325i 4 door sedan with 180,000 miles on the odometer.
    The engine was rebuilt in 7500 miles (9months) ago. TOP and BOTTOM, so this is for all intent and purposes a brand new engine ready to do another 180000.
    Invested close to $6K in parts alone over the years, work completed by shop owner, and ASE certified master technician.This car has seen more time on a lift than most cars will ever see in their lives.
    Originally the vehicle was an automatic, and had tan comfort interior. I converted it to 5spd manual with a Getrag 260 transmission, new clutch, and resurfaced flywheel (transmission replaced in July with a re-built unit. All new seals, synchros, and bushings). Oil changes done every 3,000 miles or earlier with 20w-50 Castrol, recently replaced coolant, transmission fluid, and differential fluid.
    Interior-
    Two-tone interior - Black / Tan
    M-tech steering wheel
    Black Carpet
    Replaced dash- currently has only a few small cracks
    M-tech shift boot
    Black sport front seats (relatively good condition for original material)
    Weighted Billet shift knob
    New window motors and switches (all 4)
    Suspension/Drivetrain-
    BrandNew rebuild power steering rack
    BrandNew power steering hoses.
    Vogtland Springs
    Bilstein Shocks
    Brand new outer tie rod ends
    Brand new front control arms
    Brand new ball joints
    Brand new M3 offset control arm bushings
    Brand new wheel bearings (all 4)
    Ireland Engineering front drop hats (NEW)
    New drive shaft center support
    4.10 Limited Slip Differential - (making this effectively the best 325is model)
    Racing Dynamics front Strut tower brace
    12mm Hubcentric spacers (front and rear)
    New clutch master/slave cylinders
    Installed Rebuilt transmission (July)
    New driveshaft guibo
    New driveshaft center support bearing
    Engine/Acc.-
    Complete Engine Rebuild just over one year ago. Head/Bottom End (NEW parts)
    Replaced Fuel Tank/Fuel Pump/Fuel Filter
    New Radiator/Fan Clutch (radiator contacted fan while engine was running, but is not damaged)
    New thermostat
    Timing belt replaced at time of engine build
    New coolant hoses
    Heated throttle body plate delete
    New intake boot
    New hood prop strut
    All new gaskets
    MAF replaced
    All vacuum lines replaced (no leaks)
    Valve adjustment done every 10,000 miles
    Extra Relays will be included with sale (I have never needed them)
    17.5# rebuilt and flow tested Bosch injectors
    Custom Exhaust split Y with quick change flange (not too loud, good tone) custom straight pipe will also be included.
    Wheels and Tires-
    Watanabe 15X7.5 RARE original true 3 piece wheels Custom Powdercoat
    Falken Azenis RT-615K 205/50ZR15 (less than 6K miles)
    Hub stud conversion (ringer racing)
    Gold extended lug nuts with key
    Stereo-
    Clarion reciever
    Hertz 6 1/2 inch speakers X4
    E30 premium tweeters
    Kicker comp 12" sub with custom enclosure
    Hifonics amp
    Exterior-
    Lachsilber Metallic - Metallic Silver good condition 7/10
    Euro Grilles
    Black Kidney Grilles
    Custom Sprayed Battleship Pearl Plasti-Dip (to protect paint)
    Custom modified front Volvo lip
    Custom modified Taurus SHO side skirts
    Rear Euro filler plate
    Black Painted window trim
    Things to note:
    - No AC
    - Sunroof guide is broken, working on replacing it.
    Current vehicle mileage is just under 180K odometer still works. The ODO mileage in no way reflects the age of this car. As stated above, the car has had quite the transformation throughout the years. It runs and drives like it is brand new.
    Included with the sale will be stainless steel braided brake lines.
    Without Rims: $7400
    CLEAN TITLE! Never been in an accident!
    No trades. Cash in hand only. No BS or tire kickers
    • Luke Girard
      • Dec 2013
      • 738
      #1817
      Am I crazy for thinking these are expensive when you can get a good condition 325is for $4,500 almost half of what most of these people are asking for?
      Want to trade my 1987 bmw 325iS. or for sale for 4,500 OBO
      1987 e30 325iS, 5-speed
      Odometer broke about 6 months ago, has about 150,000 miles
      Timing belt and water pump replaced about 5,000 miles ago
      Has a stage 2 SSSquid chip.
      Straight piped (still has cat) , will come with full stock exhaust.
      Cx racing coilovers
      Nrg hub, quick release and steering wheel
      Brand new ireland engineering short shifter
      All leather iS seats , no rips or tears
      Very nice paint
      Straight body
      No dents
      Clean title
      Stickers can be removed uponed new owners request
      Cons:
      Little rust on sunroof, can easily be replaced
      Temp gauge sometimes doesn't work, think it's a loose wire behind dash
      Chip of paint on passenger fender
      Needs tires due to camber wear
      Or get a 325es for $2,300
      1986 bmw 235 es - $2300 http://losangeles.craigslist.org/sfv...980996576.html
      I have a 1986 bmw is 325es for sell very clean runs great 169 k miles , manual transmission ,one owner , clean title any questions text me at
      • flyboyx
        • 8371
        #1818
        i agree with you that they are pretty pricy. most likely, they will take quite a bit longer to sell. and they will be sold for a pretty good amount less than is asked or they will be held on to.
        i like the white one by far the best, but there is no way i would pay anywhere close to 7k for it. the ad makes me laugh.....asking price: 7000.00 but make him an offer since there is no way he is taking less than 7000.00 for it. what is up with the interior pics? for that kind of money, i would expect to see a minty driver's seat. i bet its ripped since that shot appears to be avoided.
        Gigitty Gigitty!!!!
        • JoeP
          • Mar 2005
          • 150
          #1819
          For all you collectors with deep pockets:
          1986 BMW ALPINA E30 B6 m3 - $29990 (yardley)
          Powered by a 231 HP, naturally aspirated 2.7L six, these cars offer a broad torque curve--an Alpina specialtythe car makes for effortless performance that can easily tame S14 M3 cousins. The car is offered in a amazing running condition with 121,250 kms from new. The car is a genuine Buchloe built car with the BMW vin added to the car due to their manufacturer status in Germany.
          The interior remains all original, with green and blue-striped Recaros, Alpina steering wheel, center vent/engine monitoring computer, factory number plaque and wooden, Alpina-badged shift knob helping to differentiate the car from standard E30's. . All gauges, switches and accessories are in good working order and the dash is crack-free.
          Have clean PA title, originaly Japanesee market car, needs nothing.
          • MPLFoster
            • May 2013
            • 1490
            #1820
            jesus...
            form.follows.function IG @mplfoster
            • Schnitzer318is
              • Jan 2008
              • 2057
              #1821
              I just went from 6 oclock to midnight... *drool*
              "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
              91 318is Turbo Sold
              87 325 Daily driver Sold
              06 4.8is X5
              06 Mtec X3
              05 4.4i X5 Sold
              92 325ic Sold & Re-purchased
              90 325i Sold
              97 328is Sold
              01 323ci Sold
              92 325i Sold
              83 528e Totaled
              98 328i Sold
              93 325i Sold
              • Reichart12
                • Aug 2012
                • 2143
                #1822
                No engine pictures though...
                Instagram: Reichart12
                • TeXJ
                  • 1914
                  #1823
                  Is that Alpina really 1645 Kilos? That's 3626.604 lbs.
                  1990 325is
                  m52b28
                  3.73lsd
                  g260 (1987 325is 5spd tranny)
                  • audiquattrot
                    • May 2008
                    • 3836
                    #1824
                    unbelievable!
                    www.instagram.com/snwmble
                    #snwmble
                    Current:
                    '05 BMW M3 - Silver Grey/Imola Red
                    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
                    '15 Mini Countryman - Blazing Red/Carbon Black
                    Past:
                    '01 Audi Allroad - Light Silver/Platinum Saber Black
                    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
                    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
                    '90 BMW 325i - Schwarz/Tan sport *Sold*
                    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
                    • BobombETA
                      • Apr 2008
                      • 1575
                      #1825
                      e34 touring in need of love:
                      no affliation
                      Instagram
                      Current: 99 M3
                      Past: 84 325e, 84 528e
                      • brads2002
                        • Nov 2005
                        • 2688
                        #1826
                        Are those legit alpina wheels? I thought the valve stems were under the center cap running the air through a spoke. Maybe not on all alpina wheels though. Are the ellipsoids correct for 86?
                        Educate me
                        • E30 Wagen
                          • Jul 2005
                          • 3425
                          #1827
                          My Feedback
                          • kye
                            • Dec 2013
                            • 217
                            #1828
                            http://lansing.craigslist.org/tix/4981516633.html
                            hahaha even funnier because i checked it out on my way to post this:
                            oh yes 20's.
                            • ThatOneEuroE30
                              • Dec 2013
                              • 8626
                              #1829
                              Got in contact with owner of that green alpina it has an m20 and is a real japanese spec b6 2.7 car number 37
                              1991 318i 4dr slick top
                              Mtech 2 turbo restoration
                              • flyboyx
                                • 8371
                                #1830
                                U oughta buy it!
                                the steering wheel is on the wrong side of the car for it to be japanese spec. its probably german spec imported to japan early in its years.
                                Gigitty Gigitty!!!!
