F%$# My Luck!
  • Heysüß
    • 911
    F%$# My Luck!
    hello everybody,
    after not having fully recovered from my little sister backing up into me and breaking my headlights, driver's side fender, grill and deciding to do a steering rack swap in all this, a new person came and messed it up some more.
    my girlfriend. I admit it was probably my fault for letting her even hold the key, much less asking her to turn the key for me while I tried to jiggle a lock open. She didn't insert the key all the way and snapped it off inside the trunk's lock.
    I got it out but, as I always knew, the copy never really worked that great all it'll do at the moment is lock and unlock the doors, it wont open the trunk or start the ignition. So what are my options here? I have no idea, thanks for your time and any suggestions R3v.
    09/1989 325i 4 Door
    +M30 Swap
    +Z3 Steering Rack
  • deutschman
    • May 2008
    • 5958
    I think a lock smith should be able to make you a key from the ignition drum. It will be very expensive. Or you can call BMW and give them your VIN and see if they still have a replacement key or something or some kind of way to make it easier for the lock smith to make one for you. Thats all I can think of.
    • Ayman
      • Apr 2011
      • 4190
      fuck your luck dude.
      Hope you figure things out.
      Originally posted by yert315
      Your mother is plug n play
      • selturk
        • Dec 2008
        • 1197
        Just go to the BMW dealer with your ID and registration.
        Might cost between $50-100, it depends on locations.
        • Roysneon
          • 4505
          While your sister buys you new headlights/grilles/fender your gf can go get you a key made.
          Ps post noods of both as payback..
          Pps nmvnd r3v's pron party is over.
          Originally posted by mbonanni
          I am a pursit now.
          • Heysüß
            • 911
            i have a copy, but like I said, it doesn't work that well.
            It seems like all the tumblers got used to the worn down key and when I try to use the new and freshly cut copy it will not turn on the car or open the trunk. So I'm assuming that if a lock smith tries and makes me a copy it'll just be the same story, don't you think?
            09/1989 325i 4 Door
            +M30 Swap
            +Z3 Steering Rack
            • Adrian_Visser
              • Jun 2006
              • 2823
              Yeah I still have a broken key stuck in my passenger door lock. Never let stupid people touch the keys to an e30.
              '89 Alpine S52 with goodies
              • Heysüß
                • 911
                hahaha
                09/1989 325i 4 Door
                +M30 Swap
                +Z3 Steering Rack
                • Heysüß
                  • 911
                  so, what parts exactly do I need to purchase?
                  just new keys with tumblers? or is it going to be more expensive than that?
                  09/1989 325i 4 Door
                  +M30 Swap
                  +Z3 Steering Rack
                  • bzboardz
                    • 1096
                    take your VIN to the dealer they will give you a code which you can take to a good locksmith to have cut
                    • slammin.e28
                      שמע ישראל
                      • 12054
                      Just go to the dealer with your ID and registration. A new key cost me like $30. They had it overnight too. Not that hard to do. No locksmith shit, just ID, and registration.
                      Hint!! The address on your ID and registration needs to match Hint!!!
                      So, lets recap, you will need:
                      -Registration
                      -I.D. (Drivers lisense).
                      Go to dealer
                      Ask for key
                      Profit.
                      Also, it will be a quality, steel key! Not some brass piece of shit from ACE/Lowes. It will be an ORIGINAL CUT!!!! Perfect fitment. No more jiggling the key around and shit.
                      Seriously. OEM FTW 24/7-365.
                      • TexasTerp
                        • Jan 2009
                        • 3541
                        Just order a brand new key from the Dealer. All you need is your registration and VIN and they will order you a brand new, already cut key directly from Germany. You don't need blanks or a code for a locksmith. you'll be spending the same if not more for a locksmith. Just go to the dealership!
                        stephenbrody.com
                        • Heysüß
                          • 911
                          -Registration
                          Go to dealer
                          Ask for key
                          Profit.
                          so you guys are saying even though my tumblers are used to the old worn down key, a new key right from BMW will work perfect?
                          I don't want to get my hopes up considering my luck.
                          09/1989 325i 4 Door
                          +M30 Swap
                          +Z3 Steering Rack
                          • McGyver
                            • 4577
                            should. i've done it on both cars and never had a problem.
                            • Jean
                              • 18228
                              You will at least start with a GOOD NEW OEM KEY. You can then have the door/trunk tumbler(s) rekeyed to the master NEW key if needed.
