car is running RICH like a mofo
  • nwe30
    • Feb 2011
    • 385
    quick question, what are the main leading causes of a car running rich?
    got a nv m50 here and the smell of fuel is overwhelming.
    is the only thing that needs to be replaced an o2 sensor? any way to check if there is in fact something wrong with the o2 sensor?
  • ck_taft325is
    • Sep 2007
    • 6880
    What's your average gas mileage?
    Need a part? PM me.
    • Wh33lhop
      • 11705
      If your car smells like unburnt fuel, you may have a fuel leak... running rich doesn't really have the same odor as fuel smell unless you are catless maybe.
      paint sucks
      • nwe30
        • Feb 2011
        • 385
        ~15mpg.... it has a 4.10 lsd btw.
        • ck_taft325is
          • Sep 2007
          • 6880
          On what transmission?!
          15mpg is very, very low unless you're raping it 24/7 everytime you drive it.
          Need a part? PM me.
          • Dj Buttchug
            • Jun 2010
            • 7661
            any vac leaks? unmetered air will cause a rich condition
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • nwe30
              • Feb 2011
              • 385
              getrag 260 im sure. i'll text pierre and ask him.
              idk what's wrong!! im not raping it at all. i actually tried driving more eco-friendly. the gas tank is 16 gallons right? yeah..im getting 230-240 miles per tank
              • nwe30
                • Feb 2011
                • 385
                no vacuum leaks that i know of. car idles perfectly fine, so there has to be no leak
                • DrJosh
                  • 2011
                  Is it possible for a bad 02 sensor to cause terrible gas milage? I know it can on OBD2 cars.
                  Originally posted by Sonny
                  I am a meme for our community.
                  • Adrian_Visser
                    • Jun 2006
                    • 2823
                    ...Uh yeah. Sure is.
                    '89 Alpine S52 with goodies
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      Wrong. Unmetered air causes a lean condition, due to there being extra air (less fuel) then the computer thinks there is.
                      Leaky injectors could cause problems as well. I'd start with the O2 sensor though. You can test it with an ohm meter.
                      • nwe30
                        • Feb 2011
                        • 385
                        oops, i should fix my title then. its running rich because the smell of fuel enters the cabin of my car when im accelerating aggressively. im getting such bad gas mileage it's hurting my wallet...
                        i really need to pinpoint the problem soon!
                        where can i find the oxygen sensor?
                        • Eecen
                          • Jun 2010
                          • 1235
                          'eh? It's screwed into your exhaust somewhere after the headers.
                          And if you're smelling raw gas inside the car while driving..well I'd stop driving it until you find your issue.
                          • nwe30
                            • Feb 2011
                            • 385
                            so i should look into the exhaust system ie headers/exhaust in the engine bay? or do i need to get under the car?
                            well...it only smells like fuel when i really stomp on it.
                            • Adrian_Visser
                              • Jun 2006
                              • 2823
                              Well it could be your O2 sensor or its wiring, it could also be the coolant temp sensor or a leaky injector. Nice editing of the OP too lol.
