My $125 Driveshaft Nutty Nut
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    So Yesterday I finally wrestled the driveshaft off my car to continue with the 5 speed swap but not without a nice fat hit to the wallet.
    Saturday we began removing everything under the car needed to start the swap. Everything went super smooth until we got to the 4 nuts that hold the driveshaft to the rear differential. We spent 3-4 hours, and after one injured hand, 2 cans of PB Blaster, and $5 spent on a new 17mm open end wrench and we were only able to get 3 of the 4 nuts off the bolt stems. So we called it a day and cleaned up our war wounds.
    Yesterday, in a fit of rage I decided that bolt was coming off no matter what. Thus I spent another $120 on a new fancy 2.5 Ton 24" jack, a new set of 4 ton jack stands, and couple bits and pieces to help make the removal of the transmission bell housing bolts easier. I jacked the car up as high as I could and set up the new jack stands. Within 10 mins I had that fucker off with a set of heavy duty vice grips. I then proceeded to beat me chest and grunt while dancing around the car in a primitive victory dance. Soon after the driveshaft dropped right out.
    Everything was great until I realized I spent $120 to tackle one solitary nut.. this sucks. Well atleast now I have a sweet ass jack and in the process I got the tag off my rear dif and cleaned it up to find out which diff I had.. to my surprise... it read S3.73.. so it kinda makes up for all the hassle since LSDs were optional on 325i's and knowing my luck I was sure mine was not one.
    now how should I explain to my g/f that I spent $120 to remove a car part??
  • kylebes1
    • May 2004
    • 2804
    Why would you need to explain anything to your girlfriend.
    She'll think your tractor's sexy...
    • Tangent
      • Mar 2004
      • 476
      Those explanations should always be in the form of "with these new tools I can save us all kinds of money on maintenance in the future!". 8)
        • 34844
        look on the bright side, you won't have to use a tractor to crawl under your car anymore. :shock:
        • Digitalwave
          is a poseur
          • 6299
          Did you not have a floor jack before? If not, don't sweat it, you will need one all the time anyways. It's a worthy investment.
          RISING EDGE
          • RobertK
            • Jun 2005
            • 5864
            I had a cheap cheesey $15 floor jack but you could hardly get under the car with it.. now my car is flyin high!
            • BS87
              • 1606
              Those nut's inspired me when it came time to take off the giant nut that holds the tranny dipstick on. I sprayed PB blaster, let it sit over night, torched it, put a huge pipe wrench on it, and gave it a swift kick. I didn't feel like fucking around, and it came right off (along with the like 50 gallons of ATF that for some reason doens't drain from the pan).
              • c0rnfl4k3
                • May 2005
                • 436
                Re: My $125 Driveshaft Nutty Nut
                Got you beat, I'm planning on spending $350 - $400 tomorrow on impact tools!!!!
                '88 325
                • mikeedler
                  • 6707
                  tools are never a waste of money, they are always there. I have more money "wasted" in tools that most people have invested in their life.
                  • redbull 325is
                    • 7472
                    amen
                    Build Threads:
                    • RobertK
                      • Jun 2005
                      • 5864
                      Already got the impact tools but BMW made some of their nuts and bolts completely out of reach for even ratchets. It's rediculous. I had to buy 2 17mm open end wrenches because the first one had a 1.5-2mm curved lip that would not grip the short walled nuts on the rear diff well enough. 2 of the bolts I just FUBAR'd with vice grips and hammered a smaller sized wrench onto.
