IE motor mount FAIL
  • bimmer630
    • 1230
    IE motor mount FAIL
    Anybody else have troubles with the yellow Urethane motor mounts from Ireland Engineering?
    I got a set about a year or two ago after my stock mounts gave out, and when i pulled that engine out to put in another car, I noticed one mount had seperated. I put the car together with one stocker and one urethane, and emailed Ireland about the mount. He said there was nothing wrong with the yellow ones, but for some reason they switched to a green urethane. He did give me a new one for only 25 bucks, but in the meantime while running one stock mount, my engine moved around and my fan kissed my brand new radiator, ruining both the fan and radiator. (i was missing the small buffer piece that hits the subframe and prevents the engine from going foward)
    Anyway now im installing a new radiator, alternator (that stopped charging, gotta love this car) a fan, and IE mount.
    Well, now I discovered the drivers side yellow mount is now seperated. WTF?
    Anyone else have probs with these? is it a weak design?
  • E30Gus
    • Jun 2008
    • 781
    I've had mine for over 4 years with no problems.
    • naplesE30
      • Nov 2007
      • 1841
      Poly never last as long as oem rubber
      • SkiFree
        • Jun 2011
        • 2766
        Bimmer630 - there have been some failures due to the urethane not bonding to the metal properly. That's why IE now uses the green compound. Alternately there are many race cars that have running them over a decade without issue.
        PM me and I'll get another green one on the way this afternoon.
        ADAMS Autosport
        • bimmer630
          • 1230
          yeah but im running a stock m20, with almost no power. I just found one of my UUC enforcer trans mounts is seperated too.
          DAMNNIT
          • SkiFree
            • Jun 2011
            • 2766
            DAMNNIT
            In this case it's not how much power your running, it's simply due to improper bonding. I'll look out for your PM.
            ADAMS Autosport
            • Brandon12V
              • 1318
              DAMNNIT
              He wasn't pertaining to power in a race e30, he was talking about consistent abuse that it takes. Stock power or not. The mounts might be their screwup, but it was your choice to roll around on a stock used mount/no buffer and screw up the fan/radiator. Sucks dude, I know. My car's been sitting on jackstands for months now because I've been having issues with various parts that have not been built properly. Hope you get it squared away.
              Originally posted by Ryan...
              It now emits a beautiful blue-ish yellow/green smoke from the exhaust?? No idea what would cause that color, but I assume its good.
              • SkiFree
                • Jun 2011
                • 2766
                Snagged your email to Jeff, you have another green one coming via UPS.
                ADAMS Autosport
                • bimmer630
                  • 1230
                  Were there alot of complaints on the yellow mounts?
                  • InuFaye
                    • 2221
                    All of those half ass non bolt through poly mounts are garbage. THEY WILL ALWAYS SEPARATE.
                    Go OEM or go bolt through.
                    1986 Plymouth Horizon. Base.
                    • SkiFree
                      • Jun 2011
                      • 2766
                      ^ Woah, strong words there buddy.
                      You do realize that with a bolt through mount that the stress of engine vibration would be transferred solely through the bolt effectively making it a very skinny solid mount. The reason it is not a bolt through design is so the urethane can dampen/dissipate the vibration before it hits the frame (this is the same theory applied to the stock rubber mounts, just less dampening. ).
                      ADAMS Autosport
                      • e30boarder
                        • Jul 2010
                        • 41
                        I just got my engine running a few weeks ago and they seem fine. I have the green mounts for the engine but the tranny mounts are yellow, hopefully they hold up. They do make quite a bit more noise... but the engine feels nice and tight.
                        • Danny
                          • 14216
                          revshift
                          • SkiFree
                            • Jun 2011
                            • 2766
                            Originally posted by Danny
                            revshift
                            Won't even go there, do a google search and see what pops up. Not my style to bash a competitor.
                            ADAMS Autosport
                            • immajackuup
                              • Dec 2010
                              • 1132
                              i assume revshift bushing is crap???^^^
