Easiest job that took the most time
  • dna1943
    • 39
    I replaced the rear bumper on my 92 convert along with the two bumper shock absorbers. The shocks went on easy but the bumper took 5 hours. Two stinkin' bolts. Five hours on my back. First one side started but other wouldn't. Take it down, make sure everything is OK and try again. Right side is Ok but not the left. Repeat and start the left side but the right feels like it is working but won't catch. Ugh, cover the ears of all the kids in the neighborhood. Finally everything lined up and it went right on and I don't even know what I did different. I had to keep repeating to myself "This is my hobby and I'm having fun" over and overand over.
    Thanks for letting me vent. I have had 9 other BMWs and this one is the newest so I'm not new to this "fun".
    Has anyony else had this kind of problem?
  • Kershaw
    • 11822
    wow dude. you really should have contacted some local e30 people.
    you can swap bumpers in about 20 minutes.
    AWD > RWD
    • scottinAZ
      • Dec 2009
      • 1312
      putting on the goddamn clutch fan. 5 minute job at the outside, took an hour and a half. Freaking thing did NOT want to line up to spin on. walked away, had a stiff drink, and the fucker went straight on........
      I saved 15% on my Bimmer parts by switching to ...
      • lambo
        Captain Scene Points
        • 10953
        Changing oil. Turned out the threads were stripped :D
        • slammin.e28
          שמע ישראל
          • 12054
          I had one helluva time adjusting my seat once.
          • Violet88
            • Jun 2010
            • 435
            lol
            '88 325i cabbie royal blau
            '91 325i cabbie calypso rot
            '92 318i cabbie laguna green
            ~I like all my b!tches topless ;-)~
              • 34839
              my last timing belt did NOT want to go on. I spent probably 90 minutes just trying to get the belt on the sprocket. usually I can do the whole thing in that much time without a rush.
              • Mlarsen
                • 4082
                I had the exact same problem when I put my belt on.
                • 5Toes
                  • 9836
                  Sometimes, you just GOTTA walk away.
                  • fsf1o1
                    • Jul 2011
                    • 141
                    hehe
                    Freaking Seats
                    1989 Toyota Liteace- Surf Mobile Forsale http://www.r3vlimited.com/board/showthread.php?t=215019
                    2012 Porsche 911 Black Edition-Sold
                    2007 E-Class 350 -Sold
                    • Balleristic31
                      • Aug 2009
                      • 4198
                      Stupid shifter cup bearing. That thing took me all day to get. Ugh
                      -NICK
                      • devon.818
                        • Feb 2011
                        • 2937
                        the control arm. had the old one off in 20 minutes(from time i put jack under car).
                        spent 6 HOURS messing with the new control arm bushing/loli pop/ and new control arm.
                        finally took it to a machine shop. then took me about 25 minutes to bolt it all back together and get car rolling again. lol lame
                        • schtozo
                          • 1455
                          Battery tray in trunk, the bolt head was stripped and rusted, after an hour i hammered a flat head screw driver around it to cut the plastic and remove it.
                          One of the best threads you will ever read
                          http://www.r3vlimited.com/board/showthread.php?t=221813
                          Nice trailer of my e30
                          http://www.youtube.com/watch?v=TTjtG...e_gdata_player
                          If i sold you something please leave feedback here
                          http://www.r3vlimited.com/board/showthread.php?t=217142
                          • Earendil
                            • 1662
                            Having done the water pump and timing pump on my own car 3 times, I agreed to do a friends. I was a little slow, taking the time to get everything perfectly right, and 3-4 hours later it was all buttoned back up with new coolant. Started her up and the coolant came gushing out at about 5 gallons a minute.
                            I couldn't tell where it was coming from because it was all put back together, and it was getting dark. So the very next evening I did the entire thing all over again. I found a little extra gasket residue around the pump and spent 45 minutes carefully polishing that surfacing and making sure it mated together perfectly. I found nothing else even close to wrong (brand new hoses and claps) and assumed I had it under control. All back together again and she leaks just as much! Arg!
                            A bunch of research later reveals that the bolts on the water pump sometimes sink into the coolant area. So I took it all back apart, sealed the threads on the bolts, put it back together, and it hasn't leaked a drop since. I've never put a drop of anything on the water pump bolts on my own car. Live and learn.
                            So I spent about 14-15 hours total on a @#$%ing water pump.
                            The other common dice roll of a common repair is dropping and reattaching the exhaust. I've slapped that biotch back on in 15 minutes by myself. I've also spent 90 minutes with a friend trying to wiggle it into place.
                            1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
                            2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
                            I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
                            • Pantless Spency
                              It's McRib time!!!
                              • Feb 2011
                              • 7283
                              Fucking amen!!!! I changed mine out for a used one that also ended up bad and that took an hour then took it off and had to put a brand new one on, such a bitch to thread, not to mention hitting your knuckles on the rad, and going to a shop to borrow there pulley wrench twice haha
