will this work?
  • Dj Buttchug
    • Jun 2010
    • 7673
    will this work?
    If a said car has two fuel pumps, an in-tank feeder pump and an inline high pressure pump can the car be ran without the high pressure pump if you swap the intank feeder pump for a regular pump or a 255lph???
    will there be issues with pressure? I cant see how there would be. FPR controls pressure.
    Basically remove in line pump. replace space with fuel line and add a regular pump in the tank...
    thoughts??
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
  • McGyver
    • 4619
    you will want to replace the inline high pressure pump with pipe or hose. other wise you will be generating electricity by pushing fuel through the pump. so you'll have a drop in pressure and velocity.
    • Dj Buttchug
      • Jun 2010
      • 7673
      yea thats what i wanted to do. i want to take out the high pressure inline pump all together.
      Ig:ryno_pzk
      • 416stroker
        • May 2008
        • 2448
        I did it works. I just moded the lift pump housing
        84 318I Delphin RIP
        87 325IS delphin 24v Sold
        89 325 Alpineweiss
        • Vtec?lol
          • Dec 2009
          • 3278
          This will work. It was common back in the day.
          • McGyver
            • 4619
            oh, your in-tank low pressure lift pump should have a 13mm fuel line and the stock late model in-tank pumps have an 8mm line. so make sure you get a high pressure pump that wont need adapters.
            • Dj Buttchug
              • Jun 2010
              • 7673
              okay im going to do this then. thanks for the input guyss
              Ig:ryno_pzk
              • 5spoke
                • Sep 2007
                • 1729
                I was expecting this.
                • slammin.e28
                  שמע ישראל
                  • 12054
                  I have than on my e46.
                  It works.
