$10k+e30 what would you do?
  • Deltron Dirty30
    • 2436
    #31
    volvo lip and sportmaxxes.
    spend the rest on hookers and blow like a real mentlegen would.
    Instagram: @jstnlws
    • Sample UF
      • Aug 2011
      • 175
      #32
      Why is 400hp a requirement? That's stupidly overpowered for an E30, unless straight line is your thing. In which case an E30 isn't the car for you.
      Me:
      15x8's with semi slicks
      Slotted brakes and better pads
      BC Gold Coilovers
      Polyurethane bushes all round
      Thickest off the shelf sway bars
      Strut braces
      Bride/Recaro fixed backs, roll bar, harnesses, steering wheel, short shifter/ZHP
      2.7 stroker, high comp, 288cam, ITB's/Programmable ECU
      3.73 8 bolt LSD(rebuilt)
      • Bearmw
        • 1323
        #33
        What's the point of this exercise?
        • ACHTUNG
          • May 2005
          • 2397
          #34
          use it to blow lines on your cracked dash.
          1989 US E30 Cammed S52
          Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
          • e30Rooster
            • Jan 2010
            • 958
            #35
            I just wanted to see what people had to say, it helps me weigh my options.
            I haven't had the chance to build a car yet but I was thinking I should start with a reliable drive train, brakes, suspension, interior, exterior.
            • Sample UF
              • Aug 2011
              • 175
              #36
              In an older car like this, step 1 should be fixing up suspension, steering and brakes.
              These things are going to cause the most carnage if they fail.
              You don't want to put lots of money into looking nice and going fast, only to have your suspension break at 100mph.
              • JasonC
                Site Manager
                • 14451
                #37
                You wouldnt happen to know "Chaos Theory" on here, would you?
                1992 BMW 325iC
                1978 Chevrolet Monte Carlo
                • walktheboard
                  • 347
                  #38
                  m30 turbo with boost by gear
                  Originally posted by e30hijinks
                  I move faster than "the speed of light." I'm always connected to my Blackberry and am ready to purchase at a moment's notice. I do not play games
                  • Sample UF
                    • Aug 2011
                    • 175
                    #39
                    Chaos Theory?
                    I don't want to see O.P kill himself in a car with 500hp and 20 year old, worn out suspension and brakes.
                    You want to make sure your car is fully operational before going crazy with mods.
                    Edit:
                    Also, to have an engine make 400hp and be reliable in an E30 is probably going to cost you fair bit more than 10k.
                    • DuMa
                      • 1101
                      #40
                      new suspension, coilovers, swaybars, bushings strut bars.
                      5lug, 5 lug wheels
                      new door, roof, window seals.
                      z3 steering rack
                      z3 shifter
                      miller MAF + chip
                      header + exhaust
                      skid plate
                      HID kit
                      and keep the rest for maintenance.
                      • dannyyisntt
                        • 3141
                        #41
                        Turbo setup for my m30
                        Coilovers
                        Sticky tires
                        Body reenforcement
                        Depending on what/where I buy that could be more or less 10k
                        • JasonC
                          Site Manager
                          • 14451
                          #42
                          Chaos Theory?
                          Edit:
                          Chaos Theory is a member on here, im just seeing if you knew him.
                          1992 BMW 325iC
                          • naplesE30
                            • Nov 2007
                            • 1837
                            #43
                            Take said 10k and spend it on anything but my e30,,,, p perhaps save for a down payment on a rental property. Anything but dump it into a e30, as much as i love them.
                            • F34R
                              sLaughter
                              • 12376
                              #44
                              M52 turbo will get you those numbers with enough money invested. But will leave VERY little on the bone to make the e30 safe enough to handle all that power. If you drop to 300hp you will have a better e30 in the long run. 400hp is a waste in a e30 unless you are into 1/4 etc. E30s are made for driving and 400 will make that very scary ;)
                              And click my build thread below, I am sure it is over 10k by now. Complete rebuild from top to bottom. I cut no corners and went with only top parts.
                              Instagram: @BWeissLeather
                              Current cars:
                              ~ '87 325 M30B35 swap
                              ~ '87 535
                              ~ 01 540 Msport 6spd
                              ~ '06 X5 4.8is
                              • alB5
                                • 785
                                #45
                                buy more e30's just for the hell of it.
                                1991 318is -> 2004 R32 -> 2002 Jetta TDI -> 2014 FiST
                                No E30 Club
