325e speedometer in 325I
  • dbred330ci
    • Jul 2011
    • 7
    Thought i purchased a 325i cluster but instead i got an 325e cluster. All i need is the speedometer part. Will the 325e work properly in a 325i cluster? I have an 89 325I not sure what year the 325e cluster is. Or should i send this back through ebay and try agian. lol
    Thanks
  • Kershaw
    • 11822
    send it back
    AWD > RWD
    • AndrewBird
      The Mad Scientist
      • 11898
      Do you have both entire clusters? If so, take a look at the service indicator lights. As long as they have the same number of bars, they are compatible, regardless of year or whether it is a motometer/VDO. See here:
      • flyboyx
        • 8371
        what nitro rustler is saying is that you can probably take the coding plug out of your old cluster and the tack part to put in the new cluster. then you can just head on down the road.
        Gigitty Gigitty!!!!
        • TurboJake
          • 3780
          As long as they're both matching manufacturer (VDO and Motometer)
          You can take them apart, and use the 325e speedo in the 325i cluster.
          If the 325E cluster has the same amount of LED's in the middle, you could also take apart the 325i cluster, and replace everything BUT the speedo in the 325e one.
          Fuel gauge, and tach need to stay your current ones. Not entirely sure on the temp gauge, but either would probably work fine.
          Then sell the remaining parts
          Leave Me Transaction Feedback
          • reelizmpro
            • 9558
            To go further...84-85 eta clusters don't use coding chips for the OBC/SI board just a plastic peg. The SI board also has 3 RED LED's instead of one. You don't want to use this cluster. Now 86-on ETA's used a chip and has the SI board that has 1 RED LED (like all E30's produced after 85). This speedo is the same as the one in your 325i. It has that extra hash mark above the top speed.
            88 M3 - LACHSSILBER
            89 M3 - ALPINEWEISS II
            • Broom Broom
              • Jul 2011
              • 286
              your 89 is a facelift car, if the 325e is a pre-facelift (84-87 i think or something like that) the cluster wont be ideal as the connections and various other things were changed
              i own a 1987 325e and had to get a pre-facelift instrument cluster so the parts could be interchangebale
              - 1987 325e m20 6cyl manual -
              • JasonC
                Site Manager
                • 14451
                Just read post #3....
                1992 BMW 325iC
                1978 Chevrolet Monte Carlo
                • mkcman17
                  • Jul 2010
                  • 8240
                  for kicks i ran an 84 date eta cluster in my 89. all gauges worked except for the temp sensor, but i think it's likely a bad si board.
                  revs seemed to read more or less accurately too...to 5k.
                  1989 LN106 Hilux / 3.0TD SFA
                  1974 2002tii / stock
                  2002 IS300 / 5spd LSD
                  • dbred330ci
                    • Jul 2011
                    • 7
                    Thanks everybody, I contacted the guy he refunded my money. Took it apart after writing my first post and to odometer gears where toast so it was worthless to me now i have an extra cluster parts i dont need. I must have 3 temp, tachs, fuel, and boards. just no speedometer and odometer combo that works. lol
                    • accident
                      • 7303
                      Post #3 is where it's at. Needing to be the same manufacturer is false information.
                      Moral of this story?
