100 octane fuel melt catalytic converters?
  • rlddlr53
    • Oct 2009
    • 1450
    Will 100 octane fuel melt catalytic converters?
    For smog, My HC are 147, max 86
    I used 5 gallons of 91, 1 gallon of 100 when I got those numbers @ 15mph
    My nox, and co levels were under maximum for everything else
  • Raxe
    • 5346
    Why are you running 100 octane without a proper tune in the first place?
    • Balleristic31
      • Aug 2009
      • 4198
      Because racecar?
      -NICK
      • Joe G
        • 2942
        ^ definitely because racecar
        Current Car: 2011 BMW 135i, M-Sport, 6 speed
        Originally posted by lambo
        Sounds like you need a massage.
        Originally posted by kpeng
        Who the hell is Vlad?
        • Dj Buttchug
          • Jun 2010
          • 7680
          only if its leaded... if unleaded then no.
          Turbo M42 Build Thread :Here
          Ig:ryno_pzk
          I like the tuna here.
          • Dj Buttchug
            • Jun 2010
            • 7680
            oh yea and btw, higher octance fuel wont reduce your HC and CO. octane is the fuels ability to resist burn. so yea hotter boom but still not going bring the numbers down in most cases.
            Ig:ryno_pzk
            • u3b3rg33k
              • Jan 2010
              • 2452
              Still won't burn it up. Just make it not work.
              Ich gehöre nicht zur Baader-Meinhof Gruppe
              Originally posted by Top Gear
              Just imagine waking up and remembering you're Mexican.
              Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
              • Grant318is
                • Feb 2012
                • 291
                If it was an E36 M3, no because racer. On your average E30 be careful.
                MY BUILD: The Grant318is Build
                • u3b3rg33k
                  • Jan 2010
                  • 2452
                  Originally posted by summerscheifer
                  is your converter melt by the octane? i dont know if mine does since i own race car. any help on this please. thanks.
                  x10,000
                  • Morrison
                    • 430
                    Put a quart of xylene in with about 4 gallons of regular premium fuel. My old Eagle Talon passed emissions on this combo with no cat whatsoever.
                    "I think we consider too much the good luck of the early bird and not enough the bad luck of the early worm."
                    -Franklin D. Roosevelt
                      • 34844
                      why on earth are you using 100 octane in a street car?
                      what does that cost, about $8 a gallon?
                      • delatlanta1281
                        Dart Master
                        • Mar 2006
                        • 10317
                        Instead of spending all that money on higher octane fuel, why not donate to a worthy cause? For instance Nanado has a worthy cause in his sig.
                        And no. You won't burn it up. Not in 5 gallons.
                        Yours truly,
                        Rich
                        you kids get off my lawn.....
                          If anything I'd expect the HC numbers to be worse. The engine doesn't have the compression ratio and ignition timing to get higher octane fuel to burn.
                          What does come to mind are intake leaks, a engine running cold, leaking injectors, or a bad O2 sensor. Intake leaks cause fuel trim to increase as will an O2 sensor with 100k on it. Smoke test the intake, fix the leaks it turns up, and replace the O2 sensor. Check engine operating temperature to see if the thermostat is bad.
                          Oh yeah partial misfires from bad/wrong plugs, aged ignition wires, or a bad distributior rotor or cap are obvious possibilities.
                          • u3b3rg33k
                            • Jan 2010
                            • 2452
                            Just an FYI, 105 octane fuel ignites with a grill igniter just fine. you don't have to "get" the fuel to burn unless your pre-ignition (meaning before - not talking about combustion mishaps) cylinder pressure is so high that you're having spark blowout.
                            As proof - I point to our 6.75:1 CR farm tractor that will burn e85 with no trouble.
                            Octane Number: The octane number of a gasoline has little to do with how fast it burns or how much power the engine will make. Octane number is the resistance to detonation. If the octane number is high enough to prevent detonation, there is no need to use a higher octane gasoline since the engine will not make any additional power. Octane number is not related to flame (burn) speed either. Variations in octane quality are independent of flame speed. There are some high octane gasolines in the marketplace with fast flame speeds and some with slow flame speeds. It depends on how they are put together.
                            In short; gasoline ignites like gasoline. if it's not gasoline, it's not gasoline, and might burn differently. but if it's 85 octane high altitude gas, or 94 octane shell gas, it's still gas.
                            Flame speed barely matters - thank swirl for that. How else would you finish burning fuel in time @ 14,000 rpm?
