Ways you squeezed more horsepower out...
  • bmwguy325is
    • May 2011
    • 1263
    #31
    Originally posted by nomansland92
    ..... have you considered cross drilled brake lines?
    I did on my ex wives car. She never did stop till she hit that truck.
    I say strip off all extra body panels. Ditch all the seats. Run the OE 14 inchers and 195s. Tape the air filter upright 90 degrees into the flow of air.
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
    • Mercury[BKM]
      • Apr 2011
      • 909
      #32
      sawzall.. less metal = more power
      I can run Auto Checks on VINs for tips/donations:
      PM me VIN(s) and I'll get you ALL the public recorded info that I have available.
      paypal as gift to Mike@benzinkrieg.com
      Information/Request sticky thread for Vehicle History Reports
      http://www.r3vlimited.com/board/showthread.php?t=216119
      • tg318is
        • Jun 2008
        • 2052
        #33
        Tim.
        • Julien
          • 7472
          #34
          tuning can be tricky though, def. want to keep your egts down
          Build Threads:
          • camshaftgsxr
            • Aug 2011
            • 416
            #35
            solid motor mounts increase torque to the wheels...
            at least on 700hp trans ams they do... i donno about dinky bmws
            BroWorks.com Bro is a lifestyle
            • ogbimmer
              • Jul 2010
              • 936
              #36
              yeah that's what I was thinking, just worded it wrong I guess. what about exhaust wraps on boosted applications?
              " WHY DO YOU NEED 300HP TO DO THE SPEED LIMIT?"
              • slammin.e28
                שמע ישראל
                • 12054
                #37
                Solid mounts will make it feeeeel faster. Better for track cars, and if you like a lot of vibration.
                • F34R
                  sLaughter
                  • 12376
                  #38
                  Chrome your throttle cable, that is good for 5hp
                  Instagram: @BWeissLeather
                  Current cars:
                  ~ '87 325 M30B35 swap
                  ~ '87 535
                  ~ 01 540 Msport 6spd
                  ~ '06 X5 4.8is
                  • Mercury[BKM]
                    • Apr 2011
                    • 909
                    #39
                    what if you chrome your main harness and your ecu?
                    • Kershaw
                      • 11822
                      #40
                      i chromed my exhaust tips. that was good for 10whp.
                      chrome makes the exhaust gases exit faster.
                      AWD > RWD
                      • Sagaris
                        • Sep 2009
                        • 2243
                        #41
                        Solid engine mounts will not transmit more torque to the wheels
                        It may improve the torque response from the engine to the wheels, but the overall amount of torque stays the same.
                        You exert a force with your hand on a concrete wall, say 40 lbs, the wall has an equal and opposite reaction force of 40 lbs. You and the wall are both stationary since the forces equal eachother. The amount of deflection the concrete exhibits due to the 40 lb force of your hand on the wall is not detectable with the naked eye but it deflects a very small amount.
                        Now, you exert a force with your hand on a wall with thick foam padding. The same 40 lb force as before. This time you notice that the force you applied to the wall caused the foam padding to deflect about an inch. Even though the foam padding deflected a little bit, the wall is still reacting with the same 40 lb of force that the concrete wall reacted with.
                        Solid engine mounts deflect less for a given load than rubber, but at the end of the day, the reacting forces and moments which the engine produces are the same for each mount. The solid mounts deflect less and the deflection of the mount may reach steady state a fraction of a fraction of a second faster, but there is no more peak torque going to the wheels.
                        • ohthejosh
                          • 4963
                          #42
                          install one of these badboys, will make you faster than a neutrino.
                          SO MUCH MORE TO DO!!
                          IG: ohthejosh
                          LEGIT CHECK ME BRUH
                          BUYER FEEDBACK THREAD
                          • ACHTUNG
                            • May 2005
                            • 2397
                            #43
                            Feed the gerbils sunflower seeds under your hood.
                            1989 US E30 Cammed S52
                            Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
                            • nebulous123
                              • Jun 2011
                              • 923
                              #44
                              '84 325e - "Elizabeth"
                              '87 325e (SHELL) - "Sleeping Beauty" - COMPLETE PROJECT PART-OUT - S54, 5-LUG, and MORE
                              • Jparkr
                                HR Admin
                                • Jan 2006
                                • 3494
                                #45
                                OP go find a local gas station that does not have 10% ethanol. They are out there, and good fuel makes a hell of a difference.
                                1987 PRO-3 car /1990 325is (2.7i Concours)
