Aerodynamic Mods?
  • Dj Buttchug
    • Jun 2010
    • 7677
    Originally posted by Shangsta
    If you are honestly if you are going this far to get better mpg you need to A: Get a better paying job or B: buy a more fuel efficient car
    stfu.
    anyways
    consider the vehicle height. I have a pos early 90s volvo. I drive up to 500 miles at a time all freeway.
    Stock ride height I was seeing 25ish mpg. I lowered the car bout 3 inches all around. and saw a significant increase in mileage. almost 5 miles a gallon more.
    The new jeep grand cherokee has adjustable ride height for improved economy.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • AndrewBird
      The Mad Scientist
      • 11898
      Jordan made an undertray:
      • Regnar75
        • Sep 2011
        • 483
        Originally posted by NitroRustlerDriver
        and its soo clean!
        • kamotors
          • Nov 2007
          • 7102
          I've always wanted to see an E30 with a roof wing/deflector setup.
          7speedshop.com
          • Holland
            • Nov 2008
            • 7212
            ^ And a proper one at that. I would buy one if it was similar to the above.
            Originally posted by DEV0 E30
            • FunfGan
              • Jan 2011
              • 4958
              Really?
              And op, if you're looking for mpg, I have a link that may be able to help you. Theres a fellow on my local state forum, who owns 2 Tercels. One he builds for track events, the other as a daily to get great mpg. Both have completely different little mods. Let me know if you'd like me to dig it up!
              Go here be happy!
              Ratchet Garage e30 V8 build.
              • 750
                • 218
                Thanks for starting the thread. I started a weight reduction thread for better mpg on another forum and got 3 pages of flame.
                I had not thought about aero mods, but worth the extra effort to get what you can out of your E30. When I get to that point on my car repair I think I will start with http://www.raceskids.com/joomla/inde...emart&Itemid=3 Then just enlarge the area covering under the front of the car.
                http://www.mcnaughtonart.com/
                • Regnar75
                  • Sep 2011
                  • 483
                  Originally posted by FunfGan
                  Really?
                  ive seen quite a few mods on impoving gas mileage id like to see what hes got if you can find it
                  thanks
                  • AnimalE30
                    • Aug 2009
                    • 266
                    Did he notice any difference? I want to do something like this that ties into a skid plate to get rid of the stock splash guard.
                    • Nsquared97
                      • 1656
                      Just throwing something out there, would getting rid of the stock clutch fan and rigging up an electric one big enough to move the volume of air needed reduce drag on the engine enough to make any difference?
                      • AnimalE30
                        • Aug 2009
                        • 266
                        Reducing any type of drag on the motor is good. But you wont get a lot more power from just removing the fan clutch. Best bet would be to use underdrive pulleys too, but even then the butt dyno may not notice a difference.
                        • kamotors
                          • Nov 2007
                          • 7102
                          I didn't notice much when switching to an electric fan but technically every little bit helps
                          7speedshop.com
                          • Regnar75
                            • Sep 2011
                            • 483
                            speaking of fans......
                            Brabham BT46
                            used a huge fan to literally pump the air out from under the car.
                            also the lotus 88
                            these cars had sideskirts that were moveable, i believe they literally dragged on the ground.
                            it made the seal and sucked air out, its awesome. these things got banned because they were so dangerously good at handling they could make turns drivers couldnt handle. or they would make a turn they couldnt handle without the added grip, hit a bump, lose the suction with the ground and crash and burn...which i dont think happened but it makes me think it could. also the lotus 80 did something called porpoising. because they relied too heavily on underbody effects.
                            1969 chaparral 2J
                            • Jaxx_
                              • Dec 2009
                              • 1880
                              lower your engine bay's relative pressure. shimming the hood and removing the weather stripping do help to some extent, as do undertrays at least to the front wheels.
                              also, vortex generators on the roof... the autospeed articles are good. with that said, you get into a lot of diminishing returns. Also, don't mistake downforce for drag, or vice versa.
                              If you're that concerned about MPGs go visit a hypermiling forum(and ride on the white line on the way there...heh)
                              • iwantspeed
                                • 3164
                                you can also use this website to keep track of your mpg better
                                http://www.fuelly.com/driver/iwantspeed/325i
                                a mpg car forum im on
                                there are a lot of driving tips they give here
                                EcoModder.com - DIY fuel economy mods, hypermiling, and ecodriving for better MPG
                                Project
                                Parts for Sale
                                Feedback
                                YouTube Channel
