Reducing Cabin Noise (Ripped out my carpet)
  • mikejungle
    • Apr 2007
    • 361
    So I ripped out my carpet and sound deadening material this past weekend because I wanted to check for rust. (I found some :( )
    The first step is buying the rubber shift boot, but are there any other ways to reduce cabin noise?
    Although I might replace the carpet if a good deal comes along, I'm totally fine with the way it looks right now and I think once i put in the rubber boot, the noise will reduce dramatically (i can hear the engine roar through the hole)
    1985 325e
    mods:
    Powerflex CABs
    MOMO Corse Exhaust
    euro bumpers with BBS front spoiler
    e36 m3 shifter
    uuc clutch stop
  • blunttech
    • 12850
    That boot will help a lot. But short of putting your carpet back in I dont know of anything durable enough to take the day to day usage and make a difference in noise
    sales@blunttech.com
    www.blunttech.com
    Like us on Facebook
    • mikejungle
      • Apr 2007
      • 361
      Thanks.
      BTW, does anyone know which boot this is?
      1985 325e
      mods:
      Powerflex CABs
      MOMO Corse Exhaust
      e36 m3 shifter
      uuc clutch stop
      • slammin.e28
        שמע ישראל
        • 12054
        Spray foam. The wholefuckingthing.
        • Fixcinater
          • Apr 2011
          • 110
          Just cut out a carpet from a junkyard car. It's like $20 and 1/2 hr with a couple razor blades.
          '89 325i
          • iansane
            • 1342
            84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
            • AndrewBird
              The Mad Scientist
              • 11898
              ^^^That won't help with road noise. It will help with rattles, but do almost nothing for soundproofing.
              Seriously, why not just put your carpet back in?
              • george graves
                • 19997
                I used that e-dead stuff. It does block some engine and tranny noise. Makes the car feel a bit more "solid" going over small bumps in the road. Makes a nasty haze all over my windows even years later. I bet that roofing material would do the same, if not worse.
                Oh, and don't "cut" carpet out. You "remove" the carpet. Why you would cut it out is beyond me. The only area you might cut is around the heater core if you're too lazy to remove it.
                Originally posted by Matt-B
                • blunttech
                  • 12850
                  that looks like an early 02 boot
                  sales@blunttech.com
                  www.blunttech.com
                  Like us on Facebook
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    I've used quite a bit of the roofing stuff and while all of it is covered by the interior, I've never had problems with it hazing the windows or having any kind of smell. I've only used it to deaden panels though, not block sound. It doesn't work for that.
                    • gkobez
                      • Jan 2011
                      • 184
                      What about the dynamat stuff? Shouldn't that work?
                      • Northern
                        I like cupcakes & sh!tboxes
                        • 5234
                        Put the carpet back in or deal with it.
                        Originally posted by priapism
                        Originally posted by shameson
                        • Joe G
                          • 2942
                          there is a liquid/spray/paint like stuff that supposedly works really well. I forget the name, but i know there is youtube video of some guy putting it in a subaru.
                          Current Car: 2011 BMW 135i, M-Sport, 6 speed
                          Originally posted by lambo
                          Sounds like you need a massage.
                          Originally posted by kpeng
                          Who the hell is Vlad?
                          • FunfGan
                            • Jan 2011
                            • 4958
                            Yeah im confused why you no buy new carpet? I mean, If my car was purely a street car I'd HATE not having carpet. I can give you a ride in my car though, then your's will seem like a library.
                            Go here be happy!
                            Ratchet Garage e30 V8 build.
                            • mikejungle
                              • Apr 2007
                              • 361
                              Hey blunt, is this that part? Why are there two different OEM shift boots? I don't know what you mean by early 02
                              http://realoem.com/bmw/showphoto.do?id=25111220581
                              The one in the picture above has 3 apparent ridges while the one in the link has 2 and a big flap that I think goes into the hole.
                              BTW, i got the standard rubber shift boot and it helped kill most of the cabin noise. My car's always been noisy, so I don't mind it too much. My original question was phrased poorly, but I wanted to ask if there were any other sources (like the hole to the transmission) that were big contributors to cabin noise.
                              I cut out my carpet, because it had holes around the dead pedal area and i thought that if i was going to put one back in, it wasn't going to be the same one. My original plan was to dye the carpet, but that was before i discovered the holes.
                              For now, i'm content with the way it is. Thanks for the input.
                              But if anyone positively knows what that other shift boot in the picture is, please let me know.
                              1985 325e
                              mods:
                              Powerflex CABs
                              MOMO Corse Exhaust
                              e36 m3 shifter
                              uuc clutch stop
