Billiard Ball Shift Knob
  • scottinAZ
    • Dec 2009
    • 1312
    Always liked the look of a billiard ball shift knob (dont know why, just do), so I made this one up.
    Originally I just bored out the back side of the ball to fit the shaft, however friction wasnt enough to keep the ball in place on the shift lever. Today, I got bored and decided to do something about it. This thread is the result
    Took a piece of steel the appropriate diameter for both the ID on the billiard ball, and the OD of the shift lever, and made the appropriate hole.
    Then took an old screw, and used that to make the cross piece that prevents the knob from rotating on the lever.
    Bored out the hole in the ball to the OD of the insert
    Inserted the steel adapter into the ball. The grooves in the shaft will hold enough JB weld to make the insert permanent
    Installed into car. Need to move the shift boot up a bit to cover the bit of lever that is visable.
    The screw is a bit offset, and large enough diameter that it grabs into the groove on the lever. if this is not enough, Ill put set screws into the knob to secure it.
    Total cost to make the knob was under 5 bucks (for the ball) and about an hours labor time on this:
    Not the fastest, but it kept me out of trouble on a boring day.....
    I saved 15% on my Bimmer parts by switching to ...
  • warmseth
    • Jan 2011
    • 313
    Feels period correct. :D That is a polarizing design to be sure, but I for one, like it!
    90 325is
    85 RZ350
    75 RD350
    7? RD400 race bike
    • Raxe
      • 5346
      I really really wanted to do this with a red 3 ball on my hellrot 318is, but I lack the skills and don't feel like learning. Nice work.
      • Robotin
        • Jun 2011
        • 4471
        love the old school style... i have a crystal door knob sitting around my house from my old truck... i wish i could use it....
        ive always wanted to use a 9 ball....or custom make a bmw/e30 ball.... with M flag...
        1989 325i SETA stroker [delphin] R3V'd 8/31/2011
        1989 325ix [zinnoberrot] $OLD
        1970 2002 [Nevada]
        Originally posted by Herr Faust Schinken
        guy must have slid into something that doesn't look like a car vs car hit
        Originally posted by ak-
        Must of slid into Rob
        • downforce22
          • Aug 2009
          • 3193
          nice, looks cool.
          but clean that ash tray and center console area, disgusting!
          • scottinAZ
            • Dec 2009
            • 1312
            the camera flash makes it look worse than it is......
            • kway
              • 1084
              Nice! I'm thinking a 2 ball (blue) would go pretty nice in my Lapisblau '84...
              '84 318i - Lapisblau/Schwarz (in cryosleep)
              '06 330i - Titansilber/Schwarz
              • BoxDriver86
                • Jul 2009
                • 912
                I like this almost as much as you like Mountain Dew.
                • mikeedler
                  • 6707
                  I used to have a bowling pin as the shift knob/lever in my old mini-truckin days 1994 gonna have to see if I can find a pic. Had a PBR tap in it for a while too- way before it was hip!
                  • iamsam
                    • Jun 2008
                    • 176
                    i did this also, but I tapped a 9/16" thread into the ball and tapped the shift lever and just threaded the ball on using some plumber's tape. If I were to do it again, I would mill a flat into the ball where the tapped hole is and use a jam nut on the shift lever to help hold the ball in place.
                    • scottinAZ
                      • Dec 2009
                      • 1312
                      I thought about doing this as well, but this way, I can go back to a normal shift knob if I so desire. No permanent changes were made to the car.
                      • Fusion
                        • Nov 2009
                        • 3659
                        Had this in my old car and loved it.
                        Gives you a different throw because of the weight, but I liked it.
                        • Isostar13
                          • Nov 2011
                          • 288
                          Looks great. How's the feel/weight? Not too slippery?
                          1988 325ix
                          • scottinAZ
                            • Dec 2009
                            • 1312
                            it has a bit of heft to it, no moreso than a factory weighted knob, and fits my oversized meatclaw damn nice. The ball I got doesnt feel slippery to me, but then again, I dont often drive with sweaty palms (the hair on them helps too)
                            Keep in mind that I made this from a genuine billiards ball, it isnt a knockoff plastic readily available premade knob. if you have ever played billiards, you know what they feel like.
                            • Jand3rson
                              • 37587
                              You need this now to go with that:
                              And a pair of these:
