Can someone tell me which is better?
  • Jand3rson
    • 37587
    I'd go with a Gallo 12, or a Gallo 24.
    • BlackbirdM3
      • 2772
      Personally I wouldn't do a motor swap. I'd build the stock motor into something bitchin and unique. Id rather see a hot stock motor under anyone's hood than something that really doesn't belong. Turbo it, stroke it, long rod it, bore it, all the above and have something special. To do a motor swap into an older car is not cheap unless it is a direct bolt in and all the electrical is plug and play (I highly doubt it. ;) )
      That said, if I had a run of the mill E28 and found an S38 sitting around with no M5 to put it in, hell yes I'd stick it in the E28. I'd likely do a full rebuild on it first however.
      Will
      '88 BMW M3
      • der affe
        Technical
        • Dec 2005
        • 8452
        LSx and a 6 speed...........i am willing to build a motor once. If it does not work out or i am not happy with it, that is the direction i am going.
        • Kershaw
          • 11822
          gallo 24.
          dohc is the way to go.
          AWD > RWD
          • slaterd
            • Jul 2011
            • 1731
            Will
            And after you have to take out another mortgage because of this you can relax in your 20+ year old car.
            Originally posted by Wh33lhop
            This is r3v. Check your vaginal sand at the door.
