chip octane mpg
  • lolcantturn
    • 4588
    chip octane mpg
    sup. I have a TRM 91 octane chip on my M50 (no knock sensors) swap but I've always used 87 (never saw any butt dyno difference). However should I be running 91 for mpg sake? Would I actually see a difference in mpg even though I'm going to be paying .30$ more a gallon? Thanks
    Originally posted by TSI
    OEM+
    • 34844
    if the chip is tuned for 91, you should be using 91. otherwise, you may as well sell the chip because you aren't making any use of it.
    • lolcantturn
      • 4588
      Figured. I just haven't felt any posterior dynamometer difference at all running 91 for a few days.
      OEM+
      • bowtie2bimmer
        • 830
        Alot of the reason too is since they raise the limiter its to reduce the chance of predet
        1987 BMW 325ic - Emma
          • 34844
          what? rev limiters have NOTHING to do with detontation.
          • bowtie2bimmer
            • 830
            a rev limiter is directly related to valve float , i know that'
            but it's commonly accepted that as you rev higher and internal temperatures raise it increases the likelyhood of predet
              • 34844
              you aren't going to get valve float on a BMW unless you money shift it. and it's not going to cause detonation, either.
              these aren't GM V6's....
              • bowtie2bimmer
                • 830
                haha ironic you said that... last car I owned was a s10 with a 262 v6 for 9 years lol
                • mikeedler
                  • 6707
                  out of curiosity, why would you need to run 91 octane if it isn't detonating?
                  and weak valve springs will cause an M20 to "valve float"- that's why the rocker arms snap off.
                  • lolcantturn
                    • 4588
                    I'm curious about this as well, definitely no knocking or any adverse affects from me running 87 as opposed to 91, and I don't feel a difference in butt dyno, but I'm curious if its a difference in MPG?
                    OEM+
                      • 34844
                      you have knock sensors.
                      the chip increases ignition advance. but since you're running 87, the computer just retards it back until it stops knocking.
                      • lolcantturn
                        • 4588
                        There are no knock sensors on a M50 non vanos.
                        OEM+
                        • lolcantturn
                          • 4588
                          yes or no on the mpg?
                          OEM+
                          • Kershaw
                            • 11822
                            you might see better. 87 explodes slightly quicker and slightly more violently than 93.
                            only way to really tell is drive for a month (better averages than 1 tank) with 87 and then 1 month with 93 and chart your mpg.
                            AWD > RWD
