How did this even happen? Be honest
I broke my transmission's penis
Originally posted by Exodus_2pt0 View PostHow did this even happen? Be honestOriginally posted by TimKninja View PostHow did you know it even broke?Originally posted by RUFFLZ View Postho shit you were yoloing tho huh?Originally posted by acolella76 View PostDo you have the part that broke off? What I would do, as ghetto as it may sound, is drill and tap a hole into both sides, and thread a set screw or something into one side and screw the other side on. With a bit of red loctite it should stay.
Had three people in my car and some luggage in the trunk...pretty good tires...2.79 diff...grade 8.8 bolts on the guibo...decided to peel off from a dead stop really quick, before I even got anywhere my driveshaft broke loose, heard a bunch of bolts flying on the ground, followed by the output shaft piece.
Good thing I only lived once that day
I hope I can find the part that broke off...........Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+
Originally posted by FunfGan View PostI've got a spare m42 trans, that should work right?
trolololololYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by Wh33lhopVANOS: sometimes you just need to go full retard.
Originally posted by trackjunkie21 View Postthat's what he has now lol. So yes.Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+
Originally posted by lolcantturn View PostYup, I'm running an M44 Trans (aka G240) that came from a really low mileage 318ti so its fucking perfect and amazing. Except its like kind of broken now lolZinno '89 <24v swap in progress>
Originally posted by acolella76 View PostKind of perfect and amazing.. except for the broken pilot shaft lol
My trans brace isn't made too well (swap car), so the trans is tilted about three degrees to the right. The output shaft was broken this entire time but only now when my bolts failed did the shaft fall out and meet its demise.Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+
