speedo bounce with video and Bob Seger
  • bastianshaw
    • Jan 2007
    • 2210
    is this SI batteries?
  • e46s54dr
    • May 2008
    • 1059
    Maybe bad signal from sensor? Have you tried hitting your dashboard to solve the problem? Lol.
    • bastianshaw
      • Jan 2007
      • 2210
      Funny you mention it. When driving w the cruise on, if I tapped n the speedo w my finger the needle would twitch and cc would disengage.
      • e46s54dr
        • May 2008
        • 1059
        Did this just happen recently? Have you touched anything toward the differential area lately? It might be a bad connection from the speed sensor on the diff or a bad connection from the back of the cluster. Mine had the same symptoms awhile back and it ended up being the cluster/speedo itself.
        • bastianshaw
          • Jan 2007
          • 2210
          http://blog.bavauto.com/6280/1984-bm...0-e23-e24-e28/
          i tucked my bumpers which couldve sprayed oil on the diff?
          • Wh33lhop
            • 11705
            Speedo isn't run off of the SI batteries like the tach is. Definitely a bad connection somewhere. Does it always do that or just some of the time?
            paint sucks
            • e46s54dr
              • May 2008
              • 1059
              I dont think oil would get it to do that. The fact that the cluster responds to finger taps leads me to believe that the problem is somewhere in the vicinity of your cluster. Have you done anything else lately prior to this problem? For the most part, new problems that occur are usually due to old problems we fix if the time frame are close. Lol.
              • e46s54dr
                • May 2008
                • 1059
                Hope this helps but heres what I did to fix mine. I also re-soldered a couple of other points to fix my erratic coolant temp needle also.
                • nebulous123
                  • Jun 2011
                  • 923
                  thats boss, leave it.
                  "why does your speedo bounce?"
                  "because e30car"
                  '84 325e - "Elizabeth"
                  '87 325e (SHELL) - "Sleeping Beauty" - COMPLETE PROJECT PART-OUT - S54, 5-LUG, and MORE
                  • bastianshaw
                    • Jan 2007
                    • 2210
                    "because e30car"
                    HAHA! I just bought this car and it just started doing this the odo doesnt run when the needle quits and the problem is very intermittent.
                    Guess im pulling the cluster
                    • bastianshaw
                      • Jan 2007
                      • 2210
                      ok so i pulled the cluster and it appeared normal also unplugged the diff plug inspected and returned to service still getting intermittent speedo. Can someone exolain the system please?
                      • TurboJake
                        • 3780
                        Mine did this before I reflowed all of my solder joints on the cluster PCB. Took all of maybe 20 minutes to do including cluster removal and installation.
                        Leave Me Transaction Feedback
                        • Adrian_Visser
                          • Jun 2006
                          • 2823
                          Explanation: e30 intrument clusters are gay.
                          Something is always fucking up in them just pick a gauge and it will fuck up eventually.
                          You can try reflowing the solder, as the issues usually are from cracked solder joints, I have tried this with mixed sucess.
                          '89 Alpine S52 with goodies
                            • 34839
                            Probably the diff sensor plug. It gets crusty and causes issues.
                            • bastianshaw
                              • Jan 2007
                              • 2210
                              So it goes from the diff straight to the cluster?
