speedo bounce with video and Bob Seger
    • 34844
    Pretty much, yes.
    • bastianshaw
      • Jan 2007
      • 2210
      can I even buy a new plug for the diff?
        • 34844
        you can reuse the plastic part, it just snaps together. the pins you can buy new, they come with a length of wire so you can splice them in.
        • bastianshaw
          • Jan 2007
          • 2210
          ok but there is no "black box" to convert the mechanical signal to electric?
            • 34844
            it's not mechanical. the signal goes straight to the speedometer. the speedometer translates that signal into a stepper motor movement (speedo needle) and a basic signal for the SI board, OBC, DME, cruise control, etc.
            • bastianshaw
              • Jan 2007
              • 2210
              Thanks nando. If I have to resolver do I need to pull the speedo out of the cluster housing?
                • 34844
                I guess it depends if and what's broken. it just unplugs - not too tough to get apart. :)
                • Gregs///M
                  • Mar 2012
                  • 2459
                  The speed is easy to take apart. Just open the cluster, remove the green connector from the rear. Pull the 4 screws out and pull the speedo outward. It pulls right out of the housing.
                  The solder contact points are all pretty large so its not too bad re-flowing everything.
                  Owner - Bavarian Restoration
                  BMW and European Electronics Repair and Restoration
                  www.BavRest.com
                  My Feedback Thread
                  Our Facebook!
                  Follow our Instagram!
                  • bastianshaw
                    • Jan 2007
                    • 2210
                    Thanks fellas I've swapped speedos before, just wasn't sure what I was re flowing. This car only has like 77xxx miles on it do keeping the odo working is a top priority.
                    • akorcovelos
                      • Dec 2006
                      • 1149
                      My cluster is doing the same thing, except the speedo, tach, temp, and econo are all spazing. It makes a click noise over and over, but odo still works.
                      Keep us posted on your progress/solution.
                      2012 MCSCC/NSSCC CP class champ
                      HSAX Instructor
                      • LJ851
                        • 7919
                        I think "night moves" would have been a superior choice given the circumstances.
                        Lorin
                        The M30 is God's engine.
                        • bastianshaw
                          • Jan 2007
                          • 2210
                          Well played sir. Well played indeed
