A little fabrication fun this weekend
  • JasonH
    • 434
    Check this out...
    **EDIT: See images below**
    It was fun AND functional. You can't beat that, eh? Thanks to RedBaron86325 for getting such a cool Christmas present!
  • OldUser1
    • 636
    Red X's.
    • LikeCDoos
      • Jan 2004
      • 2522
      yup
      • Jon325i
        • 6934
        Better try again. Nothin' but red X after red X.
        Rides...
        1991 325i - sold :(
        2004 2WD Frontier King Cab
        RIP #17 Jules Bianchi
        • JasonH
          • 434
          Ack! Better get a new image hosting service. Let's try this again.
          • diegom6
            • 4447
            so, for what porpouse is that? wet in oil something? :?:
            Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
            • JasonH
              • 434
              It is an oil distribution block for my motor swap. It allows for the use of aftermarket senders (pressure and/or temp) while maintaining placement of the stock sender.
              • diegom6
                • 4447
                hehe, here is mine, I use it to feed my turbo :D
                PD: Of corse yours has better looking than mine
                • reelizmpro
                  • 9558
                  Looks good but are you guys sure you left enough room for the VDO sender? Once it's installed it looks like it'll be right against the block.
                  88 M3 - LACHSSILBER
                  89 M3 - ALPINEWEISS II
                  • JasonH
                    • 434
                    This particular one is going on the M52 motor for my motor swap, so clearance really isn't an issue. You are correct about clearance on an M20 block though. We actually checked it out on a spare block and discovered that the same design would work (even with the large VDO sender) if the threads were changed for the M20 sender and block.
                    • Bryson
                      • 1490
                      looks like you've got the lathe up and running :) my adapter for my gauges leaks a bit of oil :( no matter. Damn that looks pretty though
                      talked to my dad again and he said check the clearance on the crank sensor for your motor, if it's too far away, nothing will fire
                      • RedBaron86325
                        • 386
                        I have some extra aluminum if you want to mill one for yourself. Some pretty minor modifications to Jason's template will net you basically the same thing for the M20 with plenty of clearance. I also have some aluminum sheet if you want to update your cold air intake.
                        Don't forget the good things Hitler did.
                        • The Barvarian
                          • 162
                          I am looking for one of these for my m20 motor. I have not been able to find a commercially made product. Any thoughts?
                          Dave
                          "Life's Journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting...Holy S**t!! What a Ride!!"
                          • gearheadE30
                            • Jun 2007
                            • 3734
                            I also need to do this, but on an M42. Any ideas?
                            Project M42 Turbo
