talk me in or out of a LS swap for my vert
This topic is closed.
  • LuckyHenriksen
    • Jun 2010
    • 4244
    #31
    Something I've always wanted to do. Go for it!
    Bahama Beige E23 Project
    Bluebird Bus Conversion
    New Oregon Trail
    • lambo
      Captain Scene Points
      • 10953
      #32
      If you have to ask r3v...
      ...it's not gonna happen.
      • Robotin
        • Jun 2011
        • 4471
        #33
        just be ready to go really fast in a straight line. and have a car that handles terribly with all that weight in the front. and i hope you intend to upgrade your brake system as well. and hopefully your suspension will will right for having that huge motor in the front.
        sometimes people forget what goes into a REAL motor swap like that...
        1989 325i SETA stroker [delphin] R3V'd 8/31/2011
        1989 325ix [zinnoberrot] $OLD
        1970 2002 [Nevada]
        Originally posted by Herr Faust Schinken
        guy must have slid into something that doesn't look like a car vs car hit
        Originally posted by ak-
        Must of slid into Rob
        • iansane
          • 1342
          #34
          So what you're saying is you know absolutely nothing about that engine family?
          84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
          • Mlarsen
            • 4082
            #35
            Do it, then post pictures and a burn out video before you wreck it.
            • Jason89i
              • Sep 2004
              • 875
              #36
              I have an ls2 in my e30m3. (and buddy put one in his 325.) They are silly fast. The first time i drove it, i said to myself.... "what have you done!?!" Its not the horsepower that is astonishing, its the low end torque. Anything below 80mph and the tires are hunting for grip. the step up from the s54 was staggering.
              invest in RaceLogic traction control. enough said.
              • tonerrrr
                • Jul 2011
                • 935
                #37
                do it b/c racevert.
                instagram: @tonerrrr
                High resolution E30 Fuse Box 300dpi PNG
                • future rs
                  • Aug 2012
                  • 514
                  #38
                  uh... the ls series motors are aluminum block v8's...
                  I would venture to say that the Ls series motor is lighter than the m20/m50 by a bit.
                  • garretvs
                    • 464
                    #39
                    Our car weighs 85lbs more than stock ... don't believe the clean-hands pansys at Car&Driver, Motor Trend, etc who claim to be able to "feel the difference" of a few more lbs, or a couple percent change in F/R balance.
                    An extra 85lbs up front is about like having a 110lb passenger in the front seat ... the only guy on the planet that would notice the difference is Michael Schumacher.
                    Besides, with an LSx up front, you can steer with the throttle.....:p
                    E30-LS1 aka. 357is
                    email us to pick up our LS1 swap guide
                    E30-LS1 KITS now available!!
                    E30LS1@gmail.com
                    e30ls1.com
                    • dnguyen1963
                      • Nov 2011
                      • 2651
                      #40
                      Anything is possible...Remember, Jay Leno had a Taurus SHO engine inside a Ford Festiva and that thing was kick-ass (0-60 in 4.5 sec).
                      • dnguyen1963
                        • Nov 2011
                        • 2651
                        #41
                        I want your car!
                        • evandael
                          • Oct 2009
                          • 2881
                          #42
                          ..An extra 85lbs up front is about like having a 110lb passenger in the front seat ... the only guy on the planet that would notice the difference is Michael Schumacher..
                          i could notice the difference when i had a 110lb passenger up front... in my eta ;)
                          OP, you do know the engine cost is only the tip of the iceberg, right? you have to source and modify the oil pan, you need a transmission, modified driveshaft, maintenance items, the mounts, hydroboost system, the cooling system. do you have access to lifts, hoists, tools, or a welder? above all of that, is your suspension up to the task of managing 400hp? what about brakes, wheels, and tires? have you upgraded or maintained all the bushings all over the chassis? will you invest in chassis stiffing upgrades?
                          a $2k LSx does not a proper swapped e30 make.
                          • hfabricius
                            • 608
                            #43
                            Whatever you do, make sure you have every part you need for the swap before you take the current power plant out. That way the LS will go in that much faster with out so many hold ups.
                            http://halden-fabricius.tumblr.com/
                            • devon.818
                              • Feb 2011
                              • 2937
                              #44
                              ok mr know it all, we had a good talk at lunch about this. started budgeting things out, 2k for motor, 3-4k in parts and some outsourced machine work, but most labor could be done in house. theres a porche 944 we got a lein on, found a adapter plate to use that transmission behind the LS motor, modified corvette oil pan was our go to but without pulling my motor was tough to say. definately not a "over night" turn around, more like a year or so project, and a project in every sense. i think about this everyday lol, this motor is litterally on a stand right by my box, i think its stalking me....freaking rediculous.
                              but the fact that im incurring major tool debt ATM kinda makes me want to hold off on all of this, so as of now, idk, but i do know that motors been there for a solid year and probably isn't going anywhere, so i have time to think on it.
                              • VinniE30
                                • 2113
                                #45
                                What are your goals for the car?
                                For example, do you want a good comfortable classy daily driver? A drag race car? A drift car? A road race car? Do you want it to be humble and fast or do you want it to be an obnoxious and fast attention-getter?
                                Different strokes for different folks.
                                The thing is, people get obsessed with HP and TQ numbers. 90% of what makes a car fun is qualitative, not quantitative. There becomes a point where more hp does not always equate to more fun and it's not really usable, you can't drive the car all out. Remember, there will always be someone faster, so if your just trying to out do people, you're never gonna be happy.
                                Have you thought about a 24v swap? Much easier and keeps the characteristics of the e30. Well documented swap, reliable, good gas mileage, very smooth and revs up quick. Faster than most cars on the road and just looks and feels right in an e30.
                                Zinno '89 <24v swap in progress>
