Injector lbs ?
  • slammin.e28
    שמע ישראל
    • 12054
    #31
    Just throw some injectors in the trunk to even out that 50/50 weight distribution.
    • freeride53
      • 11972
      #32
      1983 Peugeot 505 STI
      1992 Volvo 240 Wagon
      • Tamataz
        • Aug 2011
        • 319
        #33
        Originally posted by dnguyen1963
        Hey, if you go with the metric system (like the rest of the world), let's go straight for the 1000 g injectors...1 ton injector sounds soooo cool.
        Umm, 1000 grams equals 1 kilo. 1000 kilos = 1 ton lol.
        Anyways, 1 ton injector would be too heavy for the engine, wheels have been known to fall off because of this.
        Originally posted by Raxe
        They make the car faster because they're yellow, and yellow is higher up on the rainbow than blue. Yellow had to cover a greater distance than blue in the same amount time when the rainbow arced from left to right, therefore yellow = faster.
        #elic
        Listen to this man!
        Originally posted by Sagaris
        He wasn't around because he spent 7 years in jail for assault. There was a group of guys doing a 24v swap on someones car and one of the neighbor kids came over and starting too many questions. Tempers flared, sawzalls did work, and he cut the kids leg off. The victim later joined this forum under the name "5toes".
        • frankie591
          • Feb 2012
          • 545
          #34
          throw an old m20 in there too.
          12 cylinder e30.
          throw some old valves in the trunk too.
          24 valve m20's.
          48 valve m40 + e30 =
          • dnguyen1963
            • Nov 2011
            • 2648
            #35
            Listen to this man!
            See what happen when you don't use metric system for over 30 yrs? Yes, 1 ton = 1000 kg.
            • kingston250
              • Sep 2012
              • 3
              #36
              Interesting post. These injectors are more useful and also have nice features like less weight and faster then other.I must try to buy this injector and replace.
              Craigslist Colorado Springs
              Craigslist Washington
              • 10Toes
                Me Father Was A Tree
                • Jan 2008
                • 61222
                #37
                Fuck me, I have 6 42lbs in my E30. This explains why its so slow with 252lbs of extra weight.
                WTB: 6 2lbs injectors.
                • Jalves619
                  • 596
                  #38
                  I loled
                  • flyboyx
                    • 8371
                    #39
                    if you search the internet really really hard, you can buy some ghey injectors. they are generally light of foot and will save at least 12.2 lbs/per. this will get you down into the 6.7 lbs/hour range and solve all your problems. just do the math. you will see.
                    Gigitty Gigitty!!!!
                    • dnguyen1963
                      • Nov 2011
                      • 2648
                      #40
                      Wow, too early to decipher this email!
                      • The Volta
                        • 321
                        #41
                        Anyone ever solve this issue?
                        My Build
                        • ELVA164
                          • 4861
                          #42
                          Drill a hole in each injector and then slam it into a wall: Viola, tucked injectors. Saves many kg's and also some lbs, not to mention the fuel reaches the spark plugs faster for more hp's. Most E30s are capable of wheelstands after this mod.
                          • Andy.B
                            • Sep 2011
                            • 1650
                            #43
                            The whole post made me smile, but...
                            this was the only post in this thread to make me genuinely laugh.
                            • The Volta
                              • 321
                              #44
                              Bump
                              My Build
                              • Kershaw
                                • 11822
                                #45
                                BRB changing my injector set up.
                                AWD > RWD
