E30 s5x
    E30 s5x
    Just for genereal knowledge, what kind of 0-60 times does a e30 with a s5x put down and how does it hold up to lets say a e46 m3?
    Flame suit on.
    e46 M3 stands no chance because they all have rubber band tires and a flat brim capped bro piloting them.
      This
      1991 318is S52
      1987 325i Vert
      1991 325i
      2011 e70 X5
      Need Anything E30? -> http://www.gutenparts.com/
        Just look through this thread. You'll probably find your answer.
        Dude this is r3v. 20 bucks gets you a used timing belt or a low mileage head gasket
          Flame suit on.
          here's an s50 e30 vs e46 m3
          Zinno '89 <24v swap in progress>
            Flame suit on.
            even the earliest S50 swapped E30's were faster than an E46 M3. I'm thinking Stu here...
              thanks guys i have a 1991 318is with koni single adjustable ground control springs 16" style5, was stuck on between swapping my e30 or buying a e36 m3 and supercharging it
                You won't make friends with post like that! Swapped E30 > E36
                Hell, for the amount of money you'd spend supercharging an E36 M3, you could swap and supercharge/turbo your E30.
                  A fully done S50/S52 can keep up to a point. My S50 E30, which dynos at 215ish rwhp on a dyno that is generally known for reading low, is roughly 15-20mph slower down the main straight at Summit Point. (The E46 would redline 4th and spend some time in 5th for around 150MPH.)
                  A well driven E46 M3 is flat out going to be faster. With the right driver, a stock E46 with DRs can get into the high 12s. And it will consistently run low 13s with competent, but normal drivers.
                  2002 BMW M3 Alpinweiß/Black
                  1999 323i GTS2 Alpinweiß
                  1995 M3 Dakargelb/Black
                  - S50B32/S6S420G/3.91
                  1990 325is Brilliantrot/Tan
                  1989 M3 Alpinweiß/Black
                    Not true. Supercharging an E36 M3 with a good kit and good parts (gauges, clutch, tune, 3" exhaust etc) costs about $4-6k. S50 swap on an E30 costs $4-6k at least and then another $4-6k on top of that for boost.
                    E36 M3 is also a much more stable platform for boost and easier to fit wide tires on.
                    RIP: Delphin '89 E30 with S50 swap and lots of goodies :'(
                    Then: '04 Evo 8 RS, 500 whp/420 wtq 2900 lb E85 AWD turbo shits 'n giggles
                    Now: 2003 BMW M5 in Sterling Gray
                      Not to mention the e36 m3 has way better rear suspension.
                        Not true. It would even out in the end, he already has the e30, not the e36.
                        E30
                        S5x Swap: $4,000
                        Boost: $5,000
                        Total: $9k-$10k
                        E36
                        +$3-$4,000 for selling his current e30
                        $6-$9,000 for an e36 M3
                        Supercharger/Turbo: $5,000
                        Taking the median price for a decent E36 M3 $7,500+$5,000 for boost.
                        Total minus the sale of the e30 $9k-$10k
                          E30
                          S5x Swap: $4,000
                          Boost: $5,000
                          Total: $9k-$10k
                          E36
                          Not to mention the e30 will be way faster given equivalent power.
                            the e30 is not a 0-60 car. it is not a top speed car. it is a 20-100 car, and with an s5x, it will definitely pace an e46 m3 in that category.
                            besides, any faster than that on a public road and you should (and actually might) DIAF.
                              qft...Coulnd't agree more...s52 and an e30 are an amazing combo NA and even better FI
                              Originally posted by Roysneon
                              $5 shipped?
                              Originally posted by MarkD
                              You are a strange dude, I'n not answering any more posts from you.
