E30 s5x
  • isthistherealcaesarspalace
    • Mar 2012
    • 140
    Okay so here is the situation, I have a mint alpine 1991 318is I currently have bought Koni yellow single adjustable, ground control adjustable springs, fog deletes, oem mud flaps all four, smiley, 16x8 styles 5's power flex bushing kit,zhp shift knob, Fog deletes, euro plate filler not to sound cocky but its a decent looking car that turns heads, but I just don't feel like the power is enough. I have about 5k left over on the project now I'm stuck on what to do. M30? S50? M20 Stroker? M42 Turbo? Fucck! Too many options. I want a solid car I could rape but also a reliable dd.
      • 34839
      OBDII S52 seems obvious to me. Should be doable for $5k if you don't go overboard on mods. just do a clean, reliable stock swap.
        • Mar 2012
        • 140
        Yeah right when I typed the last sentence M42 turbo was out of the question, but I love the rawness of a M20 stroker
          • 34839
          M20 stroker is fun but it's expensive to build and harder to live with day to day than an OBDII S52 would be. To be worth doing you have to do serious work on the head and have it tuned properly (not using the stock computer). that could be a $7,000+ build after tuning, and you *might* make as much power as a bone stock S52.
          for sure I'm not saying "don't do an M20 because 24v!!" because that's a pretty stupid mentality, nobody spends $10k on an E30 because it makes sense to do so. My point is not that an M20 has no potential, but a $5000 swap is going to perform better than $5000 spent on a half baked M20.
            • Mar 2012
            • 140
            I appreciate your suggestion based on you have 24k posts lmaoo but for example this guy is a local and is selling it for 3k
            2.8L M20 stroker
            M52 crankshaft bobbed & polished
            Re-sized Eta connecting rods
            Cut down B25 pistons
            Euro 323i flywheel
            Balanced & blueprinted bottom end
            ARP main bolts
            ARP rod bolts
            ARP head studs
            Port & polished head
            Custom 280 grind cam
            Ported intake manifold
            Ireland HD rocker arms
            Ireland shorty headers
            PnP Megasquirt by Dederic Motorsport
            24lb Bosch injectors
            Spal 16" electric fan conversion
            Ireland 8mm plug wires
            Custom single 2.5 exhaust by Castros
            Flowmaster Hushpower center muffler
            Flowmaster 44 series rear muffler
            • hoveringuy
              • Dec 2005
              • 2717
              It's only worth $3k.
              I've driven M20 strokers and they felt slow compared to a DOHC swap.
                • Mar 2012
                • 140
                make sense because he said he dynoed the car with 194whp
                  • 34839
                  2.8L M20 stroker
                  Euro 323i flywheel
                  ARP main bolts
                  ARP rod bolts
                  ARP head studs
                  well, it's up to you, but it's really apples/oranges.
                  I'd bet it's not even 200whp (but ask for dyno sheets, you never know) and also I've lived with a stroked M20 running megasquirt on the street for 6 years. it gets tiring.
                    • Mar 2012
                    • 140
                    thanks for the inputs guys I think s5x is the best bet
