The car now:
'87 M20B25
Rebuilt 90,000km (55,000 mi) ago
Rebuilt starter/alternator
New distributor cap, plugs, wires
Stock exhaust w/cat removed (quieter than I would have liked)
New timing belt/water pump
Front suspension revamp done + brakes
Apex Springs/Bilstein Sport Shocks
2.73 open-diff
UUC SSK w/DSSR
So I've finally got my M20B25 swapped 325e running, and I'm a little disappointed. I came from the B27, which was slow as balls but felt a little quick (obviously because of the MASSIVE eta torque). Now I didn't expect the 170hp B25 to be fast, but I guess I was hoping it was quicker than what I'm feeling.
I've recently been told there is employment opportunities for me at my parents house in PEI, which includes a large garage and all the tools I will ever need, along with my dad for help (30 years+ car experience).
So now I've got two options. I can go the route of full bolt ons -> 3.73 LSD, Miller MAF + Chip, 19lb injectors, and KAI Motors Intake. I'll probably also run a 2.5" exhaust, sways, nicer stereo, do some weight reduction, and shave the engine bay. Total is ± $1500 (buying used parts).
The second option is a 7-8psi turbo set up running on motronic ecu. Parts would include 24lb injectors, revshift manifold adaptor, Holset HY35, eBay intercooler, ARP head studs, new head gasket, BOV, Begi FMU, stage 2 clutch (maybe not necessary), TCD motronic chip, M30 AFM, and a wideband 02 + other gauges. And before you tell me to buy a PNP megasquirt, try and find someone to tune/have a dyno in rural PEI farm country is not possible.
The greatest thing is that the car is not a DD, because I am not in need of a DD. I live in downtown Montreal, with an 8 minute commute to school. The car is stored at my friends house in the suburbs, where I only really drive it on weekends. However, it will need to make the 1200 km from PEI to Montreal at the end of the build.
While the price difference is quite significant (buying used parts, ±$1500/$2600), I'm more worried about going to bolt on route and feeling no power difference and want to turbo it anyways = $ down the drain. Also, next summer is a long way away, so I will have time to look for great deals to pop up on anything I choose.
Oh, and before you tell me to, all maintenance (hard fuel/brake lines, subframe bushings, rear brakes, tires, valve adjustment, etc) will be done before/at the same time of other modifications.
*flame suit on* Let's hear the suggestions!
'87 M20B25
2.73 open-diff
UUC SSK w/DSSR
