Quick Question
  • Zreberlcoe
    • 1555
    Quick Question
    Is this okay? My temp sits right around here at all times even on the highway, but when I'm sitting still it will creep up to right before half.
    1991 325i Calypso Coupe
    Like Grandfather, Like Father, Like Son
    BMW
  • lambo
    Captain Scene Points
    • 10953
    Yes. That's where all M20 E30's sit at when they're running correctly.
    Edit: Also, the temp gauge isn't necessarily accurate. About half the time mine is waving at me.
    • e30lov
      • Jul 2008
      • 1597
      I'm going to say your fan clutch is probably bad, or your thermostat is stuck open. Does it ever creep past the middle at all while you're sitting in traffic? Is your heat lukewarm?
      `92 325 vert - `90 325 coupe `99 m3 - Instagram @e30L
      • Zreberlcoe
        • 1555
        It hasn't done that yet but it has gotten to the point where the needle covers the halfway mark. I thought the t-stat just pops open early but I guess not.
        BMW
        • Herr Faust Schinken
          • Feb 2012
          • 3580
          you most likely have a 75 degree thermostat mine runs like that
          88 325is Five Speed
          Lachssilber
          • Wschnitz
            • 8089
            Mine never moves past a hair before the half. thats fine, right?
            willschnitz
            • Vivek
              attention whore/retard/bitch
              • 6167
              That's all completely normal. I can't get my dad's m20 too far past the pic in the OP, and my m42 is just a hair behind 1/2 no matter how hard I push it.
              1992 Mauritiusblau Vert
              2011 Alpinweiss 335is coupe
              2002 540i/6 Black/Black
              2003 GSX-R 750 (RIP)
              • spike68
                • Apr 2009
                • 1185
                Mine always sits around half. When i cruising, its just under. When Im sitting, its either at half or a hair over depending on how hot it is outside.
                I don't even own this car anymore, but I'm too lazy to change the picture.
                  • 34839
                  you probably have a 70 or 75c t-stat. the 70c sits at about the 1/4 mark. if it were me, I'd change it to the 80c, but it's nothing to worry about as is.
                  • 702pjc
                    • Sep 2012
                    • 143
                    MY first thermostat was just before half.
                    Now it runs right on half (80 degree thermostat I think).
                    • dnguyen1963
                      • Nov 2011
                      • 2649
                      It can get cold in CO. Switch out your thermostat to an 80C one.
                      • evandael
                        • Oct 2009
                        • 2881
                        +1 on switching to a hotter thermostat.. a hotter engine will probably run better, too (to a point)
                          • 37829
                          With a stock thermostat (which I recommend) the gauge should be a waffleswaffleswaffleswaffles-hair below half.
                          I've never understood the fascination with low temp thermostats.
                          Classic BMW Specialists
                          Grover Beach, CA
                          www.BimmerHeads.com
                          • dnguyen1963
                            • Nov 2011
                            • 2649
                            I like to keep my bun nice and toasty in the winter! There is no fascination with low temp tstat in the frozen tundra.
                            • Dustn525
                              • Jan 2007
                              • 76
                              This. Exactly. Running a lower temp thermostat can actually increase wear on the engine, due to friction. The tolerances are engineered to be at the optimum level of friction at the stock thermostat's specs.
                              I do what I want
                              Past BMWs: '84 325e, '89 325ic, '92 525i, '91 325ic, '89 535i, '86 325es
