This is what LA does to skid plates
  • brian52555
    • 425
    #31
    I use my Peerless plate as a jack point all the time. so convenient.
    • delatlanta1281
      Dart Master
      • Mar 2006
      • 10317
      #32
      Honestly? If your car is too low to drive, why drive it? Mine is lowered, and yes I am careful, but dump your car, don't complain when it breaks.....
      Yours truly,
      Rich
      you kids get off my lawn.....
      • euro2fast4u
        • 545
        #33
        Originally posted by FLG
        Peerless is beefy but it's welded to your frame and I remember a thread with a guy who had it take a serious hit and not only destroy the plate but tweak his frame...
        Sent from my Galaxy Nexus using Tapatalk 2
        link to thread right NOW
        • FLG
          • Sep 2011
          • 3165
          #34
          Here ya go, broken motor mounts and bent frame.....at this point ill take the broken oil pan.
          -Build http://www.r3vlimited.com/board/showthread.php?t=295277
          • akorcovelos
            • Dec 2006
            • 1149
            #35
            if he had another skid plate it would have destroyed his oil pan, oil pump, and his core support at a minimum, probably the subframe too. That is an exception, any skid plate will only do so much. There another thread where a guy drove off a cliff and destroyed the car, but the peerless plate still protected the oil pan.
            2012 MCSCC/NSSCC CP class champ
            HSAX Instructor
            • FLG
              • Sep 2011
              • 3165
              #36
              Its possible but I'm not going on "if this or if that" bottom line there's a lot of damage, there's another thread with a custom plate similar to peerless (on frame rails) where it started to tweak the rails after repeated hits... I'll find that one when I get home.
              My ejnight has taken plenty of abuse and is holding up well.
              • caffeinatedsoap
                • 360
                #37
                Originally posted by e30trooper
                Learn how to drive......
                I have yet to own a m42 car but ive had low e30's and I also live in LA. But I have yet to ever crack a oil pan.
                You car isnt that low ether. Just might need new struts and stiffer springs for slow vert :D
                I have less than 3000 miles on JOM shocks and springs. I don't think they're that great. I had ground controls with billy sports on my old 318 and it was about the same distance to the ground and it did pretty well.
                Also being from Kentucky originally I'm not use to the huge creases in the road. What is with that?
                Edit: I'm going with the Peerless plate next paycheck.
                1992 318ic
                • ZekeTheSneak
                  • 1562
                  #38
                  stiff sprangs
                  • e30lov
                    • Jul 2008
                    • 1597
                    #39
                    Skidplate? Que?
                    `92 325 vert - `90 325 coupe `99 m3 - Instagram @e30L
                    • caffeinatedsoap
                      • 360
                      #40
                      Originally posted by e30lov
                      Skidplate? Que?
                      Early 90s Caravan?
                      1992 318ic
                      • DooDanE30
                        • Nov 2011
                        • 683
                        #41
                        thats what LA does to shit skid plates.
                        • 325ix
                          • Aug 2009
                          • 7783
                          #42
                          Actually it does it's job as a skid plate pretty well. If you don't drive like a blind fucktard it is plenty enough. There is no reason for you to armor the bottom of your car unless you are careless or you are a rally driver.
                          • mr.vang
                            • 4371
                            #43
                            m42 oil pan sit a little lower than m20 pan. i had cracked 2 oil pan with the race plate with my previous m42.
                            it's pretty low though
