hyundai elantra, trans mounting issues
  • Kozworth
    • May 2011
    • 1339
    My moms elantra had an issue where i had to replace the engine w/a junkyard one.
    The engine cranksover freely with no trans. I used the trans from her old oneand the same torque converter. I removed and put the trans on multiple times, and it seems that the engine wont crank. The bell housing sits flush, but did crack a few times...
    I am wondering if this trans is somehow still not mounted correctly? is there some computer restraint that does not allow it to turn?
    The engine WILL NOT budge with a 1/2 drive wratchet in any gear on the trans..
    Thanks in advance
  • Dj Buttchug
    • Jun 2010
    • 7683
    is the auto trans in gear? you need to make sure you have the shift linkage connected at the correct position.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • Kozworth
      • May 2011
      • 1339
      Engine is out of car, if i select the gears manually on the trans no matter what I cannot get the crankshaft to move when the trans is mounted.. PRNDL all dont allow me to move the crankshaft via 1/2 drive wratchet.
