Alternative timing belt material...
  • Stephen
    Шлем ишака
    • 10774
    Originally posted by FLG
    It puts added wear on the belt. Your spinning the engine the same rpm but your doing so at a much faster rate.
    Also if your planning on doing upgrades to raise the rev limit like stiffer springs or a steeper cam, again more stress on the belt.
    Sent from my Galaxy Nexus using Tapatalk 2
    what
    • Vivek
      attention whore/retard/bitch
      • 6167
      How does that work?
      1992 Mauritiusblau Vert
      2011 Alpinweiss 335is coupe
      2002 540i/6 Black/Black
      2003 GSX-R 750 (RIP)
        • 34847
        let's put it this way: the timing belt is either 50k or 5 years, whichever comes first. it's the age of the material more than anything. the rubber will degrade due to heat cycles. RPM has little to do with it.
        • Dj Buttchug
          • Jun 2010
          • 7688
          no
          Turbo M42 Build Thread :Here
          Ig:ryno_pzk
          I like the tuna here.
          Originally posted by lambo
          • FLG
            • Sep 2011
            • 3165
            So your telling me higher rate springs, spinning the engine higher than factory , and doing so at a faster rate has NOTHING to do with timing belt wear?
            Nando, would the belt not be going through more heat cycles faster? Wouldn't a faster increase in rpm vs slower also increase heat?
            Sorry but I'm not believing that
            -Build http://www.r3vlimited.com/board/showthread.php?t=295277
            • dannyg
              • Mar 2007
              • 1553
              timing chain duh
              1993 325ic Schwarz/Natur
              1991 318is Black/Black - Slicktop - Project s52
              1989 Alpine White/Black M3 S52
              1988 Henna/Pearl M3 <3
              • HawaiianE30
                • Nov 2012
                • 81
                I know... I'll just swap out the m20 for the AMC I4.0L in my Cherokee... T-Chain ftw!
                Originally posted by e30guydownunder
                Stupid German wookie winning F1 WDC and beating Webs. waffleswaffleswaffleswaffles.
