Time Sert repair
  • long tall eta
    • Jul 2010
    • 1536
    Time Sert repair
    has anyone used the time sert oil drain plug repair kit? my plug hole is starting to strip. can this be done with out removing the pan?
    also, what size kit should i use? m12x1.5??
    The job can be done without removing the pan.
    • kingston
      • Jun 2010
      • 2669
      I also found a set up just-oversize drain pulgs for sale that I've used, since on of the POs overtorqued it. I'll see if I maybe have ohe left (had to buy them in packs of 5). It's worked a treat!
      Originally posted by LJ851
      kingston is the play by play announcer for this thread.
      ‘Tis by the grace of God that my cars run!
      Originally posted by unloadedak
      #teamross
      Siobhan's Build Thread - UPDATED!
      • DrJosh
        • 2011
        I have and it works great. Although I would not do it with the pan installed as it creates a lot of metal shavings.
        Originally posted by Sonny
        I am a meme for our community.
        • long tall eta
          • Jul 2010
          • 1536
          hey man, whats goin on? if you do have an extra, that would be great. let me know.
          bob
          • Nick_S
            • Apr 2011
            • 3655
            I need to do a few of mine, leaks a tad out the back where one of them is stripped. PO also stripped a few of the valve cover bolts too. Ugh.
            91 318is M50 swapped
            05 Honda Pilot
            24V swap thread
            • lambo
              Captain Scene Points
              • 10953
              It definitely does, just have someone with a shop vac held up to it. Also, when you're done run some clean oil through it to pick some extras up. I did it with the pan still on the car and it went in slightly crooked, unfortunately, so I just RTV'd the shit out of a fumoto valve and slapped it on there.
              • noid
                • 1536
                If you want to buy it off me after I buy and use 1 insert, let me know, then you can sell it to someone else, and so on.
                Edit: Just purchased, let me know :)
                Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
                Your resource to tools and tips: www.rtstools.com
                • long tall eta
                  • Jul 2010
                  • 1536
                  just picked a set up from flea bay. 55.00 shipped with 4 inserts.
                  • noid
                    • 1536
                    Are you sure you got the 1215 set? because I also ordered on ebay and didnt see anything in the price range your telling me.
                      That is easy to deal with. Pack the flutes of the drill with grease, drill some, then clean and repack the drill. Do the same thing with the tap. The grease traps the swarf and keeps it out of the pan.
                      • long tall eta
                        • Jul 2010
                        • 1536
                        does anyone know if i would need the small extension piece for the fumoto oil drain valve for my b27.
                        • lambo
                          • 10953
                          Yes, you do.
                          • long tall eta
                            • Jul 2010
                            • 1536
                            thanks dude, thats what i was looking for
