Crazy Find...Airtex e2448 same as Walbro 255lph
    • 34839
    #31
    I still don't get the infatuation with this pump. it's really not that great..
    • Jalves619
      • 596
      #32
      Decent, relatively cheap, and readily available?
      • iansane
        • 1342
        #33
        You don't get how people can be unnecessarily infatuated with a brand name?
        That being said, I bought one because it's cheap and flows a good amount for whatever project it may go in.
        84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
        • IronFreak
          • Dec 2012
          • 3702
          #34
          Airtex or Walbro?
          Walbro makes a good pump, has helped make a lot of hp on a lot of quality builds.
          Instagram @rebellionforge
          • agent
            Vice Grand Pubaa
            • 7960
            #35
            Originally posted by kronus
            • rustybullet
              • 218
              #36
              I work at advance and I can confirm
              • adjmcloon
                • Apr 2012
                • 446
                #37
                To me it was getting something for much less than you'd pay normally if you buy it with the Walbro box. That and I needed a new fuel pump! :D
                • Balleristic31
                  • Aug 2009
                  • 4198
                  #38
                  Got the flow rates
                  Free flow rate 55-75 Gph
                  pressure range 85-110 psi
                  -NICK
                  • MrBurgundy
                    R3V Degenerate
                    • Mar 2012
                    • 5549
                    #39
                    I was looking on their website and couldn't find this fuel pump anymore. Is this a thing of the past now?
                    • brianao34
                      • Jun 2010
                      • 660
                      #40
                      Originally posted by Balleristic31
                      Got the flow rates
                      If these specs are right then that's about the same specs for a Walbro 255lph pump.
                      High performance Walbro fuel pump sales and more by Auto Performance Engineering. Since 1997, APE has been THE place to find a Walbro fuel pump!
                      • Balleristic31
                        • Aug 2009
                        • 4198
                        #41
                        There is one on the shelf here at my autozone. Pretty readily available. That's how I pulled the flow specs.
                        -NICK
                        • MrBurgundy
                          R3V Degenerate
                          • Mar 2012
                          • 5549
                          #42
                          I was trying to get it off Advance Auto parts, so I could use that coupon and snag a few other things.
                          • agent
                            Vice Grand Pubaa
                            • 7960
                            #43
                            Nope. Got one Monday.
                            • Exodus_2pt0
                              • 5943
                              #44
                              Originally posted by Wschnitz
                              http://www.treperformance.com/FuelPu...FuelPumps.html
                              Or if you don't trust that pump these are supposed to be good.
                              Pretty sure that's what I'm running in my car now. There are some issues to be worked out as of yet, but fuel is not one of them.
                              FWIW, a friend of mine gave me the pump. It was in a blank cardboard box, but the contents looked exactly like what is above. He said it was a walboro 255 knock off. That said, he is running the same pump in his 500hp or so 2jz Miata without issue.
                              No E30 Club
                              • reelizmpro
                                • 9535
                                #45
                                I got this pump and it is a Walbro...however, it's pick up filter is too high which will lead to fuel starvation while still having fuel in the tank. I believe it's application is for a Ford Focus. The offer from Advance is good but if you just want the pump you would be better off getting a Walbro or TRE pump designed for the E30 for about the same price.
                                88 M3 - LACHSSILBER
                                89 M3 - ALPINEWEISS II
