have you evre seen a fill n drill wheel fail?
  • Bullet Ride
    • Dec 2010
    • 598
    #31
    Originally posted by FLG
    I remember the story with the guys wheels falling off.
    At that event he purchased new lugs from a vendor which were supposed to be the correct size and thread pitch. Turned out they were the correct size but wrong thread pitch... And that was the outcome.
    Sent from my Galaxy Nexus using Tapatalk 2
    If the pitch is different you won't be able to put them on unless you cross thread the shit out of them. If that's what happened then the dude who put on the wheels is "so fucking stupid" as the late Kim Jong-Il so eloquently put it.
    • FLG
      • Sep 2011
      • 3165
      #32
      Depending on the pitch they will thread without cross threading but they will sit on the edge of the thread. Yes he should have realized regardless.
      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
      • LJ851
        • 7919
        #33
        There is no possible scenario that makes him not a dumb ass.
        Lorin
        The M30 is God's engine.
        • AndrewBird
          The Mad Scientist
          • 11898
          #34
          My guess is they were 14mm nuts with the same thread pitch as his 12mm studs. So they fit on, kind of, but obviously weren't tight. How you would not notice that, I don't know.
          • Pl3wA
            • 1589
            #35
            1/10 would not suckle upon this threads reproductive organs
            • Bullet Ride
              • Dec 2010
              • 598
              #36
              +1
              Since the nut will still go on, once it bottoms out it will tighten, how much torque it can hold is another story. If he was able to torque them it was likely deforming the thread peaks, so as soon as the wheel got loaded up all the thread peaks sheared off.
              • brutus87
                • 6280
                #37
                I'd rather just get legit adapters if I can.
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  #38
                  The issue with adapters is they are at least 15mm thick, so you have to find wheels with the correct offset to run adapters.
                  • F34R
                    sLaughter
                    • 12376
                    #39
                    I would never track fill and drills, but DD status is perfectly fine. There are some AMAZING shops that do perfect fills/drills. I would NEVER run just drills. Also against adapters being used for track duty.
                    Instagram: @BWeissLeather
                    Current cars:
                    ~ '87 325 M30B35 swap
                    ~ '87 535
                    ~ 01 540 Msport 6spd
                    ~ '06 X5 4.8is
                    • mr ilia
                      • May 2011
                      • 582
                      #40
                      Originally posted by dannyyisntt
                      I put a filled and redrilled wheel on my car and it exploded into flames
                      Because Chuck Norris
                      • iansane
                        • 1343
                        #41
                        Wait, what? Track conditions are probably going to have higher static loads but much, much lower dynamic loads than street driving. And even then, much much less often. I'd do both or neither. Doing one or the other seems weird to me.
                        84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
