Coolant leak, need help fast
  • craiggroves91
    • Oct 2009
    • 3024
    Originally posted by 318iskid
    Finally found where it needs to be connected to! It was capped off too (with a much thicker rubber cap), and the realoem diagrams weren't helping too much on that front so I had no idea lol. Now I just need to find a hose for it :x Thank you guys so much for putting up with my daft ignorance!
    No Problem! Good luck, sounds like you'll get it sorted out now.
    PS. Don't go to that mechanic anymore!
    1989 BMW 325i SOLD
    1998 BMW Estoril Blue e36 M3/4/5 SOLD
    1987 BMW 325 (The Piece) SOLD
    1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
    • 318iskid
      • Jan 2013
      • 11
      Originally posted by Vivek
      I didn't watch the video but I'm 99% sure I know what the OP is talking about. That coolant passage has nothing to do with cooling the head or block. OP, order the hose from blunt tech that comes out of the plastic tube below where that hole is in the head. It's fatter on one end and thinner on the other. Connect that to the hole you're leaking from and the fatter end to the plastic pipe.
      Any chance you have the part #?
      • Vivek
        attention whore/retard/bitch
        • 6167
        I'm in class so I'm not 100% sure that's what you need, but that's what I believe it should be. You'll need to cut the hose slightly because of how it curves or it'll be under too much stress and tear. Simon has something on this in his mess under the intake thread in the m42 section.
        1992 Mauritiusblau Vert
        2011 Alpinweiss 335is coupe
        2002 540i/6 Black/Black
        2003 GSX-R 750 (RIP)
