New Tachometer shows 70mph at 4100+ RPM, problem?
    I just install a new cluster and all gauges are working expect that the Tachometer is like 3500+ RPM at 70mph and 4100+ RPM at 80mph...what is my problem? It is a 7000 RPM Tach and it's from a 325i (fit my car)...
    92 Alpine White 325iC M-Tech II Appearance Package
    Do you drive a 318? Or is it the 325iC we are talking about?
      325iC and the cluster is from a 325i...
        It sounds like that cluster has a 4-cylinder coding plug.
          That's what I was getting at.
          Should be at the bottom of the cluster in between the temp and tach gauges.
            If that's the case, where to get the 6-cylinder coding plug? If my old Tach is showing "normal/correct" RPM, can I take that the old one and put it in the new one?
            How much and where to get a new one?
              Yup, keep the original coding plug associated with you motor/ecm. I have some spares around if you need one, from many different E30's. PM me tho
              Owner - Bavarian Restoration
              BMW and European Electronics Repair and Restoration
              www.BavRest.com
              My Feedback Thread
              Our Facebook!
              Follow our Instagram!
                Thanks for your offer, I will just put in my old one and see what happen first.
                Again, thanks for your brotherhood love :p
                BTW, anyone have picture of the plug and location?
                Thanks
                  Bottom center of pic.
                  My Build Thread
                    Thanks
                      This is the one on mine...
                      It said:
                      BMW 23
                      1394321
                      S.91 003
                        yeah, that coding plug is for a 318
                        I literally just swapped the same one out. LOL
                        My Build Thread
                          Good to know, so in my case , I can just swap the old one to this one, right?
                            325i only doing 80mph at 4.1k? What kind of diff is that with?
                            My 318is is just over 90mph at 4k..
                            Different strokes for different folks.
                              yes, just swap your original.
                              My Build Thread
