Help! Broken down in Idaho. I've got battery charging issues (e30 m3)
  • synergy141
    • 113
    Hey guys, I'm on my way back from Mfest and my car has broke down. The symptoms are the same as a failing alternator but I just got the alternator tested and its working fine. I tested the battery with a multimeter while running and it shows 9volts so it's definitely not getting a charge so it's something inbetween the Battery and alt. any ideas?
  • MNE30
    • Jan 2013
    • 79
    Grounds? That's the only electrical gremlin I can think of.
    I know on the M20 there is a big ground strap from the oil pan to the frame and one on the passenger side strut tower, first things I would check.
    • BenM
      • 2184
      Belt tension or was the alternator tested in the car?
      Originally posted by BillBrasky
      E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
      1991 318i Alpine II - S50/5-lug swapped - track car
      1989 325i Cirrusblau - Daily
      1970 2500 - Malaga over Grey Cloth
      2012 F350 6.7PSD
      • oliver.r
        • Mar 2012
        • 3839
        make sure the 2 blue wires are attached to the alternator and the ground wire isn't cracked.
        double chek the fusable link in the positive line and check that its intact
        • 10Toes
          Me Father Was A Tree
          • Jan 2008
          • 61222
          What is the voltage coming off the alternator when it is in the car and running?
          • NeoMishMoo
            • Jul 2009
            • 448
            Are you around any stores and how much farther do you have to drive? You could always be ghetto like me and hook up a second battery via jumper cables and that should give you enough juice to get to where you're going. I had to do this when my alternator failed once, but I used a spare battery.
            Turn off your stereo and all lights to get the most power out of your battery(s).
            West German BMWs, they just don't make the same as they did before the wall fell.
            ^Case in point: Auto-Repair Technology. Everytime my car isn't starting or acting up I let it sit, sometimes for an hour, sometimes for days. But it eventually fixes itself.
            • Farbin Kaiber
              Lil' Puppet
              • 29502
              Where are you at?
              • ReallyDirtyThirty
                • Jul 2010
                • 449
                Not sure what set-up the M3 uses, but a voltage regulator might be causing it. My alternator was charging like a champ until the voltage regulator took a crap. It happenned really quickly for me when this part failed.
                www.truegearhead.com
                - bad decisions & questionable cars
                • pandaboo911
                  • 2070
                  I vote bad battery..
                  if you're getting 13.8v or whatever at the alternator and 9v at the battery
                  • iansane
                    • 1343
                    84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
                    • fronton
                      • Oct 2009
                      • 1262
                      two quick and easy things to check:
                      A. your c101 plug next to the fuse box is tightly secured to between male and female. Mine was losely twisted apart and causing intermittent starting issues.
                      B. your main positive cable that runs from the battery along the passenger fender: make sure none of the copper is exposed to trunk metal. This can cause a short and not allow the starter enough power and drain your battery.
                      • Gregs///M
                        • Mar 2012
                        • 2459
                        First, 9V from a car battery is dead low. I would go ahead and say you have a dead battery, needing replacement. If the battery is near or greater than 5 years old, it dead.
                        Owner - Bavarian Restoration
                        BMW and European Electronics Repair and Restoration
                        www.BavRest.com
                        My Feedback Thread
                        Our Facebook!
                        Follow our Instagram!
                        • synergy141
                          • 113
                          Found the issue, the metal cooling line that runs along the left side of the block came loose. The metal bracket snapped. This is the main alt ground commection.so I just re routed the alt ground wire to another bolt on the block temporarily .
                          • MNE30
                            • Jan 2013
                            • 79
                            Called it. Glad you found it!
                            • aPapester
                              • 215
                              Welcome to idaho(:
                              Check Out My Photography
                              aPapester Photography Facebook
