Need help stuck at work w video
  • bastianshaw
    • Jan 2007
    • 2210
    Been doing this off and on for a while. Dies at idle but starts back up everytime, has 19 pound injectors and a markd chip. I'm thinking clogged cat? I pulled over and tapped on the Icv and it helped for a second the. We t back to doing it.
  • LJ851
    • 7919
    Crank sensor maybe.
    Lorin
    The M30 is God's engine.
    • bastianshaw
      • Jan 2007
      • 2210
      Originally posted by LJ851
      Crank sensor maybe.
      i didnt know that would/could cause intermittant problems
      • Etexise30
        • Sep 2012
        • 208
        nope it wont
        • ///Bimmerfan
          • Dec 2008
          • 730
          I dont know if this will help, but I was having similar problems as you so I checked my plugs and they were all fouled out. I also had different spark plug wires on at the time that were acting up so i went back to stock and replaced the plugs and it ran like new. Hope it helps
          • E30_Pare
            • 7801
            vacuum leak.
            DREWLIENTE
            1$ PShops PM me
            • saturnv7890
              • Jan 2011
              • 696
              Yeah I'd start with the basics, smoke test, plugs, condition of ignition and fueling systems
              My Transaction Feedback
              My "build" thread
              BUY MY CAR!!
              • GT BMW E30
                • Nov 2008
                • 2491
                icv swap it out
                • bastianshaw
                  • Jan 2007
                  • 2210
                  Originally posted by E30_Pare
                  vacuum leak.
                  no but thanks
                  • bastianshaw
                    • Jan 2007
                    • 2210
                    this is interesting i have been running rich due to the 19lbs, are you running stock injectors?
                    • Mr. Schwarz
                      • Nov 2011
                      • 153
                      Is your intake boot in good shape? Can you give us a picture of your intake boot? Im willing to bet its a intake leak somewhere. I had the same thing happen with mine, the boot tore and would stall out and jerk around.
                      Edit: Running rich may be the cause of an intake leak as well. The AFM cant measure the air that is escaping in the leak post AFM.
                      • AndrewBird
                        The Mad Scientist
                        • 11898
                        Intake leaks cause a lean mixture, not rich. The engine doesn't know there is extra air.
                        • Mr. Schwarz
                          • Nov 2011
                          • 153
                          Wouldnt the O2 sensor sense a lean mixture caused by unmetered air and and try to richen it up?
                          • LJ851
                            • 7919
                            Originally posted by Etexise30
                            nope it wont
                            I guess nobody told my crank sensor to not fail intermittently, it sounded very similar to OP's car randomly for a few months before it failed for good.
                            But what do i know?
                            Lorin
                            • bastianshaw
                              • Jan 2007
                              • 2210
                              it only has so much trim but yes it will
