Need help stuck at work w video
  • saturnv7890
    • Jan 2011
    • 696
    Originally posted by LJ851
    I guess nobody told my crank sensor to not fail intermittently, it sounded very similar to OP's car randomly for a few months before it failed for good.
    But what do i know?
    qft
    They don't die suddenly, the wiring can start to go bad
    My Transaction Feedback
    My "build" thread
    BUY MY CAR!!
    • bastianshaw
      • Jan 2007
      • 2210
      forgot to mention CEL comes on
      • Dirty325ix
        • Sep 2012
        • 689
        what does qtf mean
        • milo1303s
          • Mar 2012
          • 79
          qft
          Quoted For Truth. Generaly used on internet forum after quoting someone to make sure they cannot go back and change what they've already posted. Sometimes used to express you agree with the opinion.
          • DREWHALL
            • Feb 2006
            • 1207
            have you done a stomp test to see what fault/faults it has for the CEL? That would be a good pointer to get you in a certain direction. If it has been running overly rich it could be fouling out the plugs. This can and will cause driveability issues if they're bad enough. As stated a crank sensor can start to fail, only causing issues intermittently until it craps the bed. Typically a vaccum leak will cause stalling/stumbling at idle, then once you give it some gas it runs better. If it isnt running well enough to stay idling, it is a fuel/ignition(sensors/DME included in this) problem unless you have some serious restrictions in the intake/exhaust.
            ETA: Can't view the video at work so I'm just rambling stuff off.
            • ///Bimmerfan
              • Dec 2008
              • 730
              Originally posted by bastianshaw
              this is interesting i have been running rich due to the 19lbs, are you running stock injectors?
              Ya I'm just running stock ones
              • FLG
                • Sep 2011
                • 3165
                Hard to tell from the video, if you dont let in the clutch does the rpm still follow the engine's rpm as you decelerate or does it dip down by itself?
                CPS can cause intermittent issues
                -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                • Dj Buttchug
                  • Jun 2010
                  • 7655
                  Originally posted by Etexise30
                  nope it wont
                  this is completely wrong.
                  Turbo M42 Build Thread :Here
                  Ig:ryno_pzk
                  I like the tuna here.
                  Originally posted by lambo
                  • saturnv7890
                    • Jan 2011
                    • 696
                    No matter your credibility, if you express something on the internet with absolutely confidence and certainty, it's *obviously* true
                    My "build" thread
                    BUY MY CAR!!
                    • JayDee916
                      • 304
                      I'd go with spark or air. Check basic maint items like cap and rotor and plugs and such. And take a good hard look at all vacuum lines
                      • saturnv7890
                        • Jan 2011
                        • 696
                        Any updates from OP? Did you do the stomp test at least?
                        My "build" thread
                        BUY MY CAR!!
                        • george graves
                          • 19996
                          Banana in the tail pipe?
                          Originally posted by Matt-B
