Do you regret swapping out your m42?
  • Nick_S
    • Apr 2011
    • 3658
    #76
    Will be swapping mine this fall. Will report with disappointment or joy. Although I'm guessing I'll be happy with it. The M42 is a cool high strung engine but I've grown tired of ringing it's neck out to get onto the highway at a reasonable pace.
    91 318is M50 swapped
    05 Honda Pilot
    24V swap thread
    • LowR3V'in
      • 4209
      #77
      Originally posted by ngampleh
      where you bought that e28 aluminum radiator?
      did you have same experience, right?
      Yes I have an e28 radiator with a turbo m30 but my climate is not humid.
      Here's a super thick aluminum one.
      http://www.ebay.com/itm/WINNER-HIGH-...a4a177&vxp=mtr
      • ngampleh
        • Jul 2012
        • 466
        #78
        your place better than mine, my place humidity around 90% all year
        during summer season, you will not survive if you do maintenance or mod at outdoor
        is that link same spec with mishimoto e36m3?
        An ideal upgrade for the brittle stock BMW radiator, the Mishimoto E30/E36 Performance Aluminum Radiator provides your vehicle with enhanced reliability and improved cooling efficiency. BMWs are known to have frequent cooling-related failures due to the use of numerous plastic components throughout the system. A simple coolant leak can result in overheating, accelerated engine wear, or head gasket failure. Whether you have a daily-driven E36 M3 or an M20 spinning a large turbocharger, this E30 and E36 radiator provides ideal temperatures on and off the track. Most people overlook the importance of installing an upgraded radiator in their vehicle. Along with providing increased coolant capacity, this BMW radiator improves heat dissipation, which is beneficial for both stock and modified applications.The Mishimoto E30/E36 Performance Aluminum Radiator is manufactured using durable aircraft-quality aluminum end tanks, precision TIG-welded to an efficient brazed aluminum core. The inlet and outlets provide precise leak-free connections, and all factory overflow and temperature sensor ports are present on the Mishimoto E30 and E36 radiator for use with stock sensors and hoses. This BMW radiator also includes a M12 x 1.5 Magnetic Oil Drain Plug with Dowty seal, which effectively removes metal fragments circulating in the cooling system. The Mishimoto BMW Performance Aluminum Radiator incorporates mounting points for the factory external automatic transmission cooler, and it is a direct bolt-on fit for all 6-cylinder E30/E36 models from 1988 to 1991. As with all our BMW parts, this aluminum BMW radiator includes the Mishimoto Lifetime Warranty, ensuring superior product quality and craftsmanship.
        [ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
        [ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
        Transaction Feedback
        • James Crivellone
          Head Janitor
          • 6305
          #79
          M42 is a worthless motor. No power at all, hilarious lack of torque... drives like an M3? please. At least when I get an S14 above 4000rpm it does something.
          M42 is great at one thing, being a boat anchor.
          • pmat
            • Nov 2012
            • 174
            #80
            I cant say i miss my m42 at all. They are weak and very self destructive.
            318is, m50tu g240 s3.46
