Reducing E30 weight for fun (not for tracking)
  • capn
    • Jan 2013
    • 480
    Part of the reason I was attracted to the E30 (after owning an E39 540i and E46 330ci) was the visceral feeling I got when driving it as well as how light-footed it felt in the corners.
    Initially (like many R3v members here) I thought of going into full gut mod and building a Spec-ish E30 but I have recently changed my mind. I want my E30 to be more like a swiss army knife (maintain creature comforts) and not a surgical knife (E30 Spec).
    With that in mind I do however would like to lighten the weight of my E30 without going extreme (pulling out A/C, P/S, carpeting, etc.)
    I know there are other E30ers out there with this mindset and I'd like to collect information here to see what you've done to reduce the E30 weight without going overboard.
    Let's keep aftermarket lightweight parts out of this thread since they are pretty obvious and just focus on what we can remove from the factory E30 as it sits, some examples that come to mind:
    Back seat removal (~30lbs) [You can always reinstall]
    Passenger seat removal (~35lbs) [You can always reinstall]
    Removal of sound deadening in cabin and trunk (~50lbs) [Not too much road noise]
    Removal of spare tire, tire well, jack, trim, etc. (~50lbs) [Just get AAA]
    That's 165lbs reduction so far which will be help improve in braking, handling, accelerating, and gas mileage.
    Post up other items that you can pull off to reduce weight but still maintain a daily driver.
  • Dj Buttchug
    • Jun 2010
    • 7688
    get lighter wheels
    run 1/4 tank of fuel at all times
    run small case diffs
    remove hood
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • freeride53
      • 11972
      Originally posted by Dj Buttchug
      get lighter wheels
      remove hood
      lmfao at 2 & 4
      1983 Peugeot 505 STI
      1992 Volvo 240 Wagon
      • rcsoundn1
        • Nov 2012
        • 3361
        You could also remove all of the rear interior, since no one will be sitting back there. Rear door card, seat belts, rear deck. Could remove the rear speakers as well. There are also carbon fiber trunk lids, as well as fenders to reduce weight.
        • capn
          • Jan 2013
          • 480
          Remember we aren't talking about replacement lightweight parts... just removing factory componenets :)
          • capn
            • Jan 2013
            • 480
            Do you approximate weight savings from removing rear door card, seat belts, rear deck, and rear speakers?
            • estoguy
              • May 2013
              • 1087
              Remove that press board underneath the spare tire. That's about 10-15 pounds right there. I was shocked how heavy that was. I put it back in with my patio stone for winter traction.
              Estoguy
              • DEV0 E30
                • Oct 2004
                • 8904
                Start with early 318i.
                (1984-1985 318i)
                Curb weight: 2460 lbs (1984, manual)
                2480 lbs (1984, automatic)
                2395 lbs (1985, 2 door)
                2450 lbs (1985, 4-door)
                SPECIFICATIONS SALES FIGURES PRICING COLORS 318i (1984-1985) ENGINE/TRANSMISSIONM10 1766cc SOHC chain-driven inline 4, 2 valves/cylinder, cast crankshaft101 hp @ 5800 RPM103 lb-ft torque @ 4500 RPM…
                Removing too much has a negative affect on daily drive-ability in my mind. I did it for many years when I was younger. It depends on your climate, but driving a car that is stripped on the road isn't fun for a daily after awhile. Having a car that has strategically lightened parts (not just ditched parts) and some more power with a full interior is a better option in my mind. But that's my 2 cents.
                • capn
                  • Jan 2013
                  • 480
                  I think you are referring to the tire well? It's listed at 11lbs I believe.
                  • capn
                    • Jan 2013
                    • 480
                    (1984-1985 318i)
                    http://www.strictlyeta.net/technical...ications2.html
                    To be honest unless you are deadset on gutting the car for track, buying a specific year model isn't going to make much of a difference for the daily driver folks like me :)
                      • 34847
                      so you drive around with no seats and a gutted interior?
                      cool. around here, we call that a parts car.. :p
                      • DEV0 E30
                        • Oct 2004
                        • 8904
                        If you're in a climate that rarely sees high temps, removing the entire A/C system could be worth it to some.
                        My exact point to my second part of my post.
                        Removing things can make your car look/feel clapped out. That's not "daily drive-ability" to most, and it doesn't matter how fuhraze one says they are. Eventually it gets old.
                        • capn
                          • Jan 2013
                          • 480
                          I wouldn't touch the A/C system could ruin the resale value IMO.
                          Based on my original post all we are looking at was removing stuff behind the driver (rear seats, sound deadening, trunk items, etc). The seats can be put back of course since we wouldn't want to always have it out and only in special ocassions (track days, autocross, etc.) All the carpeting, door panels, wiring, etc. are still in tact.
                          The whole point of this thread was to remove unecessary items from the car without taking away the E30s civility.
                          • Nick_S
                            • Apr 2011
                            • 3658
                            Back seat is super light. It's almost entirely foam as it clips into the body. Just leave. Over the winter I pulled the following out of my car.
                            -sub box with 12"
                            -spare
                            -jack and tools
                            -A/C and lines
                            -powersteering pump and lines
                            -windshield washer
                            -IS trunk spoiler
                            -SRS air bag system
                            Removing all this shaved about 180 lbs off the car. If I go on longer trips I'll toss the spare, jack and lug wrench back in quick but most of the time I'm within 50 miles of my house and I have 100 miles worth of free AAA towing. It certainly made a noticeable difference as the car feels more nimble and responsive.
                            91 318is M50 swapped
                            05 Honda Pilot
                            24V swap thread
                            • Todd Black 88
                              • Oct 2007
                              • 3449
                              Umm.........removing anything isn't going to make any change in driveability unless you are driving aound at 9/10ths of the cars ability. If you are driving it like that on anything but a track, you are an ass.
                              It's just going to make it less comfortable and noisy.
                              Originally posted by codyep3
                              I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                              2001 silver/Blk 325 cabby. SOLD
                              2002 325xit Sil/blk. SOLD
                              2010 F650gs twin
