what can be clunking from the trunk area?
  • UpOn3
    • Feb 2013
    • 62
    I hear low pitch clunking from the rear of the car when I go over waves that pitch the car. Sounds like the gas tank or something. Nothing obvious in my trunk...but maybe hidden? I don't think it's the RSM as the noise occurs on compression too, not only during rebound. Thought it might be the muffler internally, as I was able to make a little noise when I shook it hard from side to side.
    Any suggestions on what it can be?
    tia
  • roznic
    • Mar 2013
    • 2880
    top shock mounts, unless your jack is not mounted...
    • Cletonius
      • 2809
      How's your battery hold down look?
      - Josh
      1990 325is
      Need a shift boot?
      Looking to buy shift boot frames, PM if you have one to sell
      Here's what happens when you let the internet pick your license plate
      • 3vilE30
        • Jan 2013
        • 344
        This ^ check your rear top shock mounts, mine are currently worn out and with the radio off there is an obvious clunk/squeak.
        • TobyB
          • 5288
          Dead body stuffed up under the rear parcel shelf's starting to lose parts???
          t
          • YosemiteSam
            • Apr 2011
            • 1303
            It could also be your rear sway if it's not attached properly.
            • Herr Faust Schinken
              • Feb 2012
              • 3580
              subframe bushings can cause this
              88 325is Five Speed
              Lachssilber
              • jdt10768
                • Feb 2013
                • 484
                rear upper shock mounts
                • gtdragon980
                  • Jun 2008
                  • 1808
                  Fuck you @aloks0.
                  I have been facing this problem too and I keep doubting my Diff install. It sounds to me like the diff is bouncing in it's carriage, but I checked the mounting bolts and they were tight. The noise only occurs when going over wavy, offset bumps, and often sounds like something loose is rocking around back there. I don't want to tear my subframe apart without knowing for sure that it is causing this and my rear shocks and mounts are fairly new. I'm running bilstein sports and the billet urethane RSM's. Oh and I also cleaned my trunk out of any junk laying in the battery tray and the other side.
                  FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
                  Originally posted by scabzzzz
                  I stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
                  1989 325i - Project/weekend driver
                  2002 325i - DD
                  2005 Suzuki SV650 - Toy
                  • flyboyx
                    • 8371
                    Originally posted by aloks0
                    We hold a wide range of Portable Cabins, pre-fab structures and pre-fab buildings to meet your business needs. Security guard cabins, Porta cabins, portable toilet, staff accommodations.
                    wtf????
                    my vote is the rear upper shock mounts. they go bad all the time. other possibilities not listed is a rear axle cv joint, the rear ujoint on your drive shaft, or the mounting bushing on the diff cover.
                    Gigitty Gigitty!!!!
                    • Xat1cZ
                      • 2020
                      Those dead hookers you put in the trunk, yeah they're not dead yet.
                      • series88
                        • Nov 2011
                        • 1231
                        Beat me to it....It can be anywhere from a ton of drugs smuggled from other countries, guns, dead hookers or stolen parts. BUt seriously, most likely rear shock mounts.
                        • UpOn3
                          • Feb 2013
                          • 62
                          I don't think it's the rear shock mounts (RSM) bec those usually clunk with rebound or compression and mine seem independent of stroke. seriously sounds like something loose, usually goes in pairs at least, clunk clunk, very low pitched.
                          I also don't think it's anything to do with the drive line since it occurs even in neutral and independent of the the throttle.
                          Rear subframe mount??? How do I inspect those? Just visual?
                          I do smell fuel when tank is full so maybe mine is associated with the fuel tank, yikes!
                          • randomtask37
                            • 3154
                            double check your exhaust. I had this same problem. my rubber exhaust hangers were going bad and had a lot of extra play in them. And my muffler had a poorly positioned metal hanger which was banging on the heat shield above the muffler. was really obvious when i found it, but i struggled to pinpoint the sound too.
                            98 M3/4/5
                            • der affe
                              Technical
                              • Dec 2005
                              • 8452
                              Exhaust hanger like above or possibly your diff bushing or the diff bolts coming loose.
                              Does it clunk when you shift from first to second also?
                              If it is just from bumps in the road or hard turning, I would look at the subframe bushings.
                              You have to remember the age of our cars. If they have never been serviced, ever, just about every rubber bushing in the car is due for replacement by now.
