Why 5-lug over 4-lug......?
I guess I should have qualified that with "for a reasonable price". (not that I'm saying those wheels aren't worth the money, just not right for my purposes)
The fact that I would be paying over 3k for one set of wheels makes 5-lug more reasonable. God forbid one ever gets fucked up, I'd be out nearly a grand for just one wheel.
S54B32 swap in progress. Status: Getting ThereComment
I think it is a reason people use, but if they researched it more they'd know better.
"It's cool" is the only reason i can think of, or if there is a specific wheel you want to run thsts not in 4 lug.Comment
New e30 m3 rear hubs are $290 for the pair. I had to install new wheel bearings anyway so i said what the hell. I'm under $400 in to the rears. Still working on the fronts but should be less.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
My euro 316 project Transaction FeedbackComment
RTFM:http://www.r3vlimited.com/board/showthread.php?t=56950Comment
For some reason i'm reading this as you can just install e30 m3 hubs onto a regular e30 trailing arm (86+)
?Comment
You have to run a minimum of 15-18mm Adapters/spacers I believe, or it will rub the inside strut, It will rub if your low enough, I had Eibachs and shit rubbed on every bump. And eibachs are not low either, HR Race would for sure rub.
willschnitzComment
I came to the conclusion a long time ago......................
5 lug swap with e36 stuff SUX!!!!!!!!!!!!!!!!!!!
you cannot even put cool wheels on the car, unless your going to run super high offset e36 wheels (which there aren't that many to choose from)
best I could find with a little bit of width was 8.5" Corvette wheels that still clear front coilovers.
fixed that for you
great, but you still need to come up with calipers, brackets, and rotors from an E30 M3.Comment
All this talk with the combination of some serious cold medicine has got me on a hell bent tangent to make my 5-lug worth my while........stay tuned.sigpic
Instagram @rebellionforgeComment
I did mine because I found cheapish M-Systems and cheap E30 M3 suspension. Missing calipers and one rear hub, but mostly complete for like $250. Sold the control arms for $200 and bought the calipers and carriers used.
I can't have more than $1000 into the swap including endlinks, new control arms and bushings, rotors/pads, etc. And less than $800 into the staggered M-Systems (9j rears).
Also did it because fuh raze stance car.For all things 24v, check out Markert Motorworks!Originally posted by mbonanniI hate modded emtree, I hate modded cawrz, I hate jdm, I hate swag, I hate stanceyolokids, I hate bags (on cars), I hate stuff that is slowz, I hate tires.
I am a pursit now.Comment
