Yes it is possible to pull an engine from the side, alone, in a two car garage.
  • n3nyongmini
    • Jun 2006
    • 593
    It can be done with the AT, and the m30 went back in the same way with the AT. from the side is the only way.
    HE>i
    89 335i m30 power, 4hp22 delivery
    • noid
      • 1536
      Back in from the side:
      May there be mercy on those who try to put an engine+tranny back from the side without a leveler (sans transmission would be easy without one).
      Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
      Your resource to tools and tips: www.rtstools.com
      • efficient
        • Feb 2012
        • 3312
        Doing it from the side is a pain, I pulled and put in a new motor on a dirt surface. What a pain in the ass without a load leveled as well. It also sucked when the hoist would sink into the dirt.
        • ClayW
          • Apr 2011
          • 377
          I'll see your two-bay engine pull and raise you a single-bay drivetrain swap (M42) and suspension rebuild with no engine crane.
          1987 325e Commuter Project Blog
          1967 1600 Project Blog: www.TX02.blogspot.com
          • suruba
            • Sep 2013
            • 159
            i don't understand why you couldn't partially open the garage for a day...
            • delatlanta1281
              Dart Master
              • Mar 2006
              • 10317
              Two things.
              1 what were you thinking?
              2 nice exhaust bushing.
              3 was this before vintage?
              Fixing your car in the parking lot must have felt like a palace
              Yours truly,
              Rich
              you kids get off my lawn.....
              • noid
                • 1536
                Garage is detached and located in an alleyway with no driveway space. Pulling the car out any distance would put it in the alleyway.
                That and the garage isn't in the best of area's, so I don't desire flaunting whats in the garage by having it open all day. I dont live in the same area, I just rent a garage there, I used to live in the same area though so I am aware of the surroundings.
                • noid
                  • 1536
                  Complimentary pictorial:
                  Did I mention I helped pull the new engine?
                  New pilot bearing because auto>manual
                  So easy when using a clutch alignment tool. Blue Loctite everything, used a torque wrench and held the crank from turning with one hand and the torque wrench in the other.
                  New head on (I changed the oil filter setup from filter-to-block to what was on my original block that uses an external OEM oil cooler post picture):
                  • efficient
                    • Feb 2012
                    • 3312
                    i did the same and it makes oil change real easy but I'm thinking of putting a oil cooler on.
                    • ClayW
                      • Apr 2011
                      • 377
                      Originally posted by delatlanta1281
                      Two things.
                      1. You take what you can get when you don't have a garage of your own (I've since bought a garage with a house attached)
                      2. Holding the exhaust in place while the engine was disconnected.
                      3. Yep, right before Vintage 2011......I made it 60 miles before overheating. Didn't make it that year.
                      • delatlanta1281
                        Dart Master
                        • Mar 2006
                        • 10317
                        Yeah a big space is awesome. I remember last year on my way to go see Steve's e12 I walked by your car and your legs were sticking out. Can't remember whether it was a tranny mount, ds, or exhaust, but I do know you guys buttoned it up super quick!
                        Yours truly,
                        Rich
                        • palitatabitha
                          • Dec 2013
                          • 10
                          That must have been a huge mess by the looks of it. Hope it went alright.
                          atlantarhinoplastycritic.com
                          • ClayW
                            • Apr 2011
                            • 377
                            Yep. I remember meeting you then, Rich.
                            I had a tranny crossmember that got a little bent, so it was allowing the driveshaft and transmission to shift under load. Bent it back into place in the parking lot next to Steve's trailer. It's not Vintage if no one is doing a parking lot fix!
