Yes it is possible to pull an engine from the side, alone, in a two car garage.
  • noid
    • 1537
    Today I pulled the engine+transmission from my E30 from the side, without a leveler, alone, in a cramped ass two car garage (use it for storage also temporarily).
    Proof:
    Yes it was a nightmare, yes I had to man handle the transmission up and over at the same time I had to push the engine crane back.
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
  • MikeDE
    • 1873
    Nice...
    there's no head, does that really count??
    -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
    • noid
      • 1537
      This started out as a simple head gasket job.
      • MikeDE
        • 1873
        They all do....
        • noid
          • 1537
          Well it started as a simple headgasket job, then into a "this block needs a time-sert kit" job, into a "this block needs to go to the machinist job" into a "Im getting another block job".
          • Ocell
            • Apr 2013
            • 291
            That escalated quickly.
            Well done on pull! Now I feel like a wimp for leaving my car in the driveway to do simple things instead of working in my 1-car garage.
            91 318is Members' Rides Thread
            • E30 Wagen
              • Jul 2005
              • 3434
              I've done this as well. It wasn't fun.
              My Feedback
              • fresh_TD
                • Aug 2013
                • 2457
                Lol..I took off the head to replace head gasket, next thing I know I ported the head, intake mani and exhaust mani and replacing valve seals tomorrow..lol I told my self I will never DO this again
                Sent from my GS4 Active
                '91 318i (Alpine) - daily
                '88 325ix (Zinno) - drive here and there!
                • marshallnoise
                  • Sep 2013
                  • 3148
                  Nice job. Sometimes you have to do what you have to do.
                  I just pulled the m30 from the 735iL by myself with a hoist that couldn't get it up high enough. I had the oil pan out of the car and the tail of the transmission was dragging in the transmission tunnel. I was planning on pulling the engine and transmission out in one piece...yeah, well that didn't happen. I disconnected the transmission in mid-air and let it plop down on the cross-member. Then a little tug and the m30 came out.
                  Si vis pacem, para bellum.
                  New Hawtness: 1995 540i/6 Claptrap
                  Defunct too: Cirrusblau m30 Project
                  Defunct (sold): Alta Vista
                  79 Bronco SHTF Build
                  • noid
                    • 1537
                    I got to the point of unbolting the transmission mid air because I didn't think it was possible to lift it up and over... Then adrenaline kicked in I decided to give it one last go and man handled it out.
                    • Ray Smoodiver
                      • Jun 2004
                      • 8809
                      Looks like a classic case of "while we're in there..."
                      Best cure is to call blunt and take a couple of his suppositories.
                      • GillesBigCowboy
                        • 507
                        Nice, good thing not an auto tranz.
                        87 4dr specE30: Bitsy (lurking above), 89 4dr 325i blau, 91 318is brillrot, 90 325ivertbronzit
                        • marshallnoise
                          • Sep 2013
                          • 3148
                          Like mine was.
                          Sent from my SPH-L710 using Tapatalk
                          • lowsodium
                            • Dec 2012
                            • 289
                            I just pulled the engine out of a donor car. Since the frame was being scrapped I just cut the entire front end off with a recip saw.
                            Its nice having the motor and trans out though. I have a $700 order ready to place from pelican to replace anything and everything it needs. Its going to be nice to have no leaks.
                            Haven't you ever seen Russian Nesting Dolls? They work like that.
                            1987 325e / 2008 135i
                              • 34844
                              I would have gotten one of those HF piano dollies and dropped the whole thing out the bottom, then lifted up the front of the car with your hoist and rolled the engine out of the way.
                              that's my plan, anyway.
