Sheared bolt on crank: fixed 12/12/13
  • serdar255
    • Feb 2013
    • 395
    I was doing my timing belt and everything was going smoothly until i sheared the crank pulley bolt. :down: Any ideas on how I can get it out?
    Untitled by serdar.gurhan, on Flickr
    image (10) by serdar.gurhan, on Flickr
    PM me for custom shift knobs and stickers!
    Originally posted by marshallnoise
    You ain't done working on a car unless you are bleeding.
  • HaloArchive
    • Sep 2011
    • 135
    Use some penetrating oil, then drill it with a left hand drill and use an easy-out.
    • serdar255
      • Feb 2013
      • 395
      I don't have access to drill, do you think a 90 degree attachment would work?
      • HaloArchive
        • Sep 2011
        • 135
        It might. Make sure you use a center punch first and drill a pilot hole or use a center bit. Last thing you want is your drill to hop out or drill your hole off center.
        If you are trying to remove crank bolt and it is still torqued down to 300ftlb, I suggest drilling it out with a left bit and then using a left tap set and tap it for a nice fat bolt that you can thread in there then use to remove the crank bolt.
        • serdar255
          • Feb 2013
          • 395
          Ill pick up one of those sets and a right angle adapter.
          Any other ideas are still appreciated.
          • Ether-D
            • Sep 2011
            • 2838
            I wonder if you could drop the subframe, would it be enough to get at the crank bolt head on. If so, it could help you a lot.
            Originally posted by Andy.B
            I was born on 3/25…
            • Fusion
              • Nov 2009
              • 3659
              This saved my ass a couple times
              • Ether-D
                • Sep 2011
                • 2838
                That's just one of the 6 crank pulley bolts. I wouldn't even worry about it. I thought you meant the main crank bolt. I didn't look at the pic the first time...
                I was born on 3/25…
                • TobyB
                  • 5287
                  Start with the right angle attachment and a short section of reverse drill bit.
                  98% of the time, that does it.
                  t
                  • serdar255
                    • Feb 2013
                    • 395
                    t
                    Going to pick up a set later today
                    • serdar255
                      • Feb 2013
                      • 395
                      Got reverse bits and a right angle attachment, took 5 minutes max to fix it.
