Workbench top mat?
  • george graves
    • 20003
    Workbench top mat?
    So I've been on Garage Journal - I didn't find an answer there.
    I've seen everything from Stainless Steal custom made tops, to some guy that had an extra 20 mouse pads and glued them down(bad idea). I've seen low shag carpet (yuck, that would suck up so much oil and metal shavings), 1/4" particle board. Ect...None look like a good idea.
    I was looking for something with a bit of rubber feel. A bit of a give. Something I can take a knife to and not worry too much about. Oh and something cheap.
    At this point, I'm thinking vinyl flooring.
    I just want something easy to clean, semi-chemical resistant, and can take a few dings.
    What do you cover your bench with (if you do)?
    Originally posted by Matt-B
  • Restoman
    • Jun 2006
    • 1311
    Look for a roll of rubber 1/4 or 3/8" thick. What about cork? It might just be what your looking for!
    i'lldoitforacaravan
      • 34844
      I would use some of that 3/8 pressboard stuff. Its fairly hard, it will hold up ok to some cutting and its cheap to replace.
      • Vtec?lol
        • Dec 2009
        • 3278
        +1 on cork. We used to have some on the floor and the little bit of give was just right.
        • AndrewBird
          The Mad Scientist
          • 11898
          On my bench I use 1/4" hard masonite. on my desk I use a cutting mat. The latter may be more like what you want.
          http://www.ebay.com/itm/Self-Healing...item3cb5e0b1ca
          1/8" thick, fairly hard, not soft. absorbs cuts very well (I use exactos on it all the time). Done a bit of soldering on it as well and it doesn't seem to care, though heat will deform them.
          • srvE30
            Voodoo Child
            • Jun 2013
            • 408
            Depending on the project I'll use something like a cheap car cover. But 90% of the time it's bare. I'll grab you a pic real quick
            It's hard as a rock but really cheap.
            1989 325i Cabrio
            tyzg
            Midwest E30 Owners Gruppe Facebook
            • ParsedOut
              • Sep 2005
              • 1437
              Laminated surface MDF. Has a formica type feel but won't crack and shatter like particle board. It's cheap, cleans up spills easily and only takes small nicks when you get rough on it. Found at Home Depot.
              Here's a pic, keep in mind that is about 3 years old. Disregard the box. :)
              • ravenlord89
                • May 2012
                • 111
                I typically use rubber flooring. Something like this;
                https://www.acklandsgrainger.com/AGI...code=SALM24-1Y
                Works great for knife resistance, makes spills super easy to clean up. Little pricy, but you will never have to replace it.
                1990 BMW 325is 5spd Black
                2005 Subaru Impreza 5spd
                2015 Yamaha FZ-07
                • M-technik-3
                  • 18946
                  Cork works well. My workbench is home made so I just replace the sheet of plywood when It's torn up.
                  • Keith M
                    • 2338
                    I used stainless for duribility and easy clean up. Not cheap though.
                    • jaywood
                      • Jul 2010
                      • 4528
                      Use some 1/8" MDF from Home Depot. Cheap and easy to replace.
                      • blunttech
                        • 12850
                        I got 4 8' long sections of hardwood bowling alleys and made workbenches out of them for me and my dad a long time ago. They are beefy as hell and were free. We just hauled them away when they were redoing the lanes.
                        I supposed its not everyday you stumble across this though
                        sales@blunttech.com
                        www.blunttech.com
                        Like us on Facebook
                        • Gregs///M
                          • Mar 2012
                          • 2459
                          I just use MDF. Scratch it? No problem, sand it smooth. Stain it? Who cares, its a work bench. I'd use my MDF workbench everyday for over 4 years and my top is dirty yes, but it works perfectly fine.
                          At first I was hesitant because I thought it would soften up, crumble, or swell up with moisture. But nothing, been working great.
                          Owner - Bavarian Restoration
                          BMW and European Electronics Repair and Restoration
                          www.BavRest.com
                          My Feedback Thread
                          Our Facebook!
                          Follow our Instagram!
                          • Nick_S
                            • Apr 2011
                            • 3658
                            On mine I use 1/4in masonite. Cleans up nice, not hard like metal, soaks up liquids (although softens up eventually) and is super cheap.
                            91 318is M50 swapped
                            05 Honda Pilot
                            24V swap thread
                            • george graves
                              • 20003
                              Thanks guys.
                              I think I'm going to keep an eye out for a piece of used conveyor belt.
